Spyder Tail Lights
Old 08-16-2016, 09:37 PM
papdza's Avatar
Default Spyder Tail Lights
Anybody ever buy the Spyder tail lights ? I bought a set and there is no plug in for the reverse light.
Any known workarounds other than drilling into the housing to mount the third bulb as the original OEM bulb ?
Part # ALT-ON-TSXB08-LED-BK
Spyder Black LED Tail Lights: Scion xB 2008 - 2010 (xB2)
______________________________
Attached Thumbnails Spyder Tail Lights-2016-08-15-10.33.04.jpg   Spyder Tail Lights-2016-08-15-10.32.50.jpg
Last edited by MR_LUV; 08-29-2018 at 07:45 PM. Reason: Moved to Correct Forum by Administrator
papdza is offline
Old 08-17-2016, 06:24 PM
Greg S's Avatar
That would be because you bought tail lights for the wrong car. The Spyders are only for the 08-10 xB, not the 11-up models. This is also why you have a gap at the bottom of the light between it and the bumper. If you're set on running the Spyders I would replace the reflectors in the bumper with lights and wire them up as the reverse lights. If you want the full LED look but ones that fit and wire up properly then you need to look at the MBRO lights out of Japan. UJ-FACTORY | Rakuten Global Market: ? tail light LED ? Redlands Toyota-Corolla rumion NZE151N / NZE154N / ZRE152N / ZRE154N (H19/10-) early / late for COLIN / shark (T02025 / TTRUMION-2L-RC-04)
Greg S is offline
Old 08-17-2016, 07:32 PM
papdza's Avatar
That makes a lot of sense. Ill definitely want to run these lights so ill go with the bumper mod. :-) Thanks a ton for the help.
papdza is offline
Old 03-01-2018, 06:51 AM
Tperry1786's Avatar
Originally Posted by papdza
Anybody ever buy the spyder tail lights ? I bough a set and there is no plug in for the reverse light. any known work arounds other than drilling into the housing to mount the third bulb as the original oem bulb ?
I've always wondered of the 08 to 10 lights would fit on my 12 xB. But is the gap between the taillight and the bumper noticeable?
I can deal with the no reverse lights lol
Tperry1786 is offline
csmonte
06-26-2015 08:44 PM
zdubbs
Scion tC 2G Aero & Exterior
04-06-2015 06:45 PM
1sikxb
11-23-2003 10:00 PM
randode
16
10-01-2003 12:40 AM
ScionizeD
12
09-27-2003 11:34 PM
Quick Reply: Spyder Tail Lights
