I have a 2008 w/ 118,000 miles. What should I get on top of to get maintenance up?
This car has only had oil changes the last few years (and air filter recently done). Runs solid, no apparent problems.
I'm sure plugs/wires are due. Serpentine belt and water pump? How long do they typically last? Also thinking coolant and transmission flush are needed.
Trying to put a list together of things I should get done before they become problems.
Any input would be great.
______________________________
Last edited by MR_LUV; Oct 2, 2019 at 01:52 AM. Reason: Moved to Correct Forum by Administrator
At 10 years or 100K they recommend a coolant change. I would change the larger coolant hoses too.
Change the belt as they are time dependent.
If your water pump isn't leaking, leave it alone
Do a tranny oil change (every 50K). Air filters every 30K or sooner. Rotate tires every 10k and check brakes at the same time.
You should be able to find a schedule on-line https://www.toyota.com/owners/resour...owners-manuals
excessads
May 14, 2015 02:18 PM
ShadeOfBlue
20
Apr 23, 2009 02:58 AM
stalinthecat
Jan 30, 2009 11:32 AM
