need help for cel eliminator?
Old Nov 13, 2008 | 02:30 AM
jdmtoybb's Avatar
Originally Posted by NoLimitzInd
I have done the anti foulers and they eventually fail. I did them on my tC, then I went to the Weapon R peice and never had a problem at all.
You only need one of them. You install it on the 2nd 02 sensor. I was going to take a pic of mine installed this weekend and spaced it when I was under there.
is there a sensor after the scuba tank?and does an s pipe delete the scuba? Did'nt mean to thread jack, just trying to figure some of these exhaust parts out.Ordered a "scuba-back" exhaust, but want to extract max power and not be too loud...If it helps its the tsudo dual.
Old Nov 13, 2008 | 06:40 AM
sp2's Avatar
sp2
Defined3
the sensor is on the spipe b4 the scuba
and no the spipe dosnt eliminate the scuba it connects the scuba to the header
your not going to max your power unless you remove the scuba tank
it is very restrictive, both power and tone
Old Nov 13, 2008 | 02:11 PM
365Motorwerks's Avatar
Originally Posted by 06scioxb
I missed this about mounting 2 together with one drilled out! Good find.
Old Dec 16, 2008 | 01:04 AM
smokeya's Avatar
Forget the non fouler junk, they rust from the inside out and foul the sensor tip so bad the o2 sensor needs to be replaced, I got two quality T304 stainless steel cel fixes that matches my pipes cheaply from bargainbasementdad on ebay. I've been cel free for 5,000+ miles so far simple easy and no rust or splices...good luck dude.
MeDizzy
Oct 8, 2015 03:31 PM
Wrencher
Jul 29, 2015 01:38 PM
umnitza
Jul 25, 2015 07:54 PM
Nateson
Apr 14, 2015 06:23 AM
bktply
Mar 17, 2015 04:50 AM
