A question about driving with an automatic...
Old May 14, 2009 | 08:11 AM
CIONIDE's Avatar
Originally Posted by buickid
Perhaps turn it to ACC, put it in neutral, then put it back to ON? Since we have electric power steering, it'll assist even if the engine is off, if the key is in ON (try it, go on a small hill, put it in ON, roll down slowly while turning the wheel, it takes a couple of seconds but the PS kicks in). Plus you have enough vacuum left in the booster for at least 2 hard stops
I'm guessing that this would be much easier to do in a controlled forethought situation, than when you're fearing for your life... but that's just me (and my brother).
Old May 14, 2009 | 08:16 AM
A-snell's Avatar
:LOL:
Old May 14, 2009 | 09:08 AM
buickid's Avatar
Practice makes perfect!
Old May 15, 2009 | 10:48 AM
Boblacks's Avatar
I read in the manual that its better to put tranny on N when at stoplight.. reason?
because it "said" it will lessen the tear on your brake pad (any part of the brake system not sure though) and will save u gas... thats what Im doin in my 09 tc...
Old May 15, 2009 | 10:54 AM
A-snell's Avatar
with a manual, U should put it into Neutral at stops. if you don't you have the clutch pressed in and that puts extra strain (wear and tear) on the clutch..
Old May 15, 2009 | 10:57 AM
Boblacks's Avatar
what i meant by manual is the booklet with full of information
What your saying is true about stick shift.. it prevent your clutch from burning,..
Old May 15, 2009 | 11:03 AM
A-snell's Avatar
ahhh. man. I must be tired....
Old May 15, 2009 | 12:36 PM
buickid's Avatar
Its not your clutch, its the throwout bearing. If you're going to be stopped for a while with a manual, its better to put it in neutral and let the clutch out so there is no load on the throwout bearing. For short stops though, leaving it in gear and holding the clutch in will produce negligible wear to the throwout bearing, which is much more easily replaced than synchro cones anyway.
Old May 15, 2009 | 12:53 PM
stillettoDSM's Avatar
I hate this kinda' stuff, my friend does this all time time since he lost his 5spd TSI.
He'll put it in N and rev while coming up to a light..
Old May 15, 2009 | 07:48 PM
Boblacks's Avatar
is he driving stick?
Old May 15, 2009 | 11:21 PM
A-snell's Avatar
that's what I meant..the throw out bearing. it was 3 in the morning when I posted that....
TotalChaos
13
Feb 4, 2015 10:24 PM
NewBox06
Feb 3, 2015 04:02 AM
akwdcaveman
Scion tC 2G Wheel & Tire
Jan 17, 2015 12:47 PM
Besk_one
Oct 18, 2003 08:41 PM
TheRedBox
Oct 8, 2003 04:25 PM
