Torque Solution Front Motor Mount / TS-XB-002
Will be installing this block of beauty Sat. What a sweet looking part
I run all their mounts on my race EVO & wanted to reduce the engine roll on the XB
Ive done enough reading to note it will increase NVH but can I live w/it? Ill let you know. If its too harsh I can always add some buffering holes in the PU bushing. Its has a durometer rating of 75
Just wanted to share the overall good looks of a well made motor mount
[IMG]
[/IMG]
[IMG]
[/IMG]
[IMG]
[/IMG][IMG]
[/IMG]
Its In!!!
Impressions. First off, XB Automatic. You will feel it at idle in drive. Driving its almost un-noticeable. Wheel hop eliminated accelerating from a stop into a hard right hand turn
As noted, its a bit buzzy in the seat at idle in drive, but I dont see myself removing it.
Labor time 1 hour. Put XB on ramps & removed battery. Remove the 3 bolts holding mount. Having no torque values to follow, I used 50ft lbs for the lower 2 bolts & 60ft lbs for the horizontal bolt
[IMG]
[/IMG]
[IMG]
[/IMG]
[IMG]
[/IMG]
[IMG]
[/IMG]
[IMG]
[/IMG][IMG]
[/IMG][IMG]
[/IMG][IMG]
[/IMG]
I ended up removing the mount & drilling the bushing to reduce the stiffness. It may have helped a bit but still too much vibration, stopped at idle in drive w/ AC on
At this point cant really recommend it for the auto XB
Well, after running it today w/the AC on, the vibration was a bit harsh, stopped at idle in drive.
I have the TRD cold air intake and my engine seems to be shaking but in the beginning when I first bought my car new from the dealer it didnt shake but now with 77k miles and my engine went out and had the bottom block replaced by the dealer I do feel it shake. And noticed its when the idle goes up and down when im stopped in Drive And I also have Strup Headers
I have a Auto and no it doesnt vibrate on Neutral kinda gets annoying at times if I pay attention to it alot. Tought it might need new motor mounts but got no idea abt motors. Im trying to learn things here on how to minimize that vibration
Anyway, you may need to have this looked at by an experienced Toyota mechanic
Well, in drive, all engines will vibrate a bit. Not sure how bad yours is. I started the thread because of the front mount modification which does not work on an auto XB ($100.00 lesson learned =(
Anyone know where I can buy a Torque Solution TS-XB-002 Front Engine Mount: for a 2nd gen xB? My FRSport order was cancelled (no longer available). I guess Torque Solutions has phased them out. Is there a vendor that might have left-overs? Or, is there a good alternative? My xB's motor is pretty jumpy and the stock mounts seem rather meek.
fluxingnation
Dec 26, 2014 04:28 PM
