2013 xB, how to remove HVAC control panel?
Old Mar 8, 2014 | 10:18 PM
OpTicaL's Avatar
Default 2013 xB, how to remove HVAC control panel?
How do I remove the HVAC control panel? I got as far as removing the panel on the shifter when I went ahead and started to pull on the HVAC panel the top seems to be on very tight and I didn't want to risk breaking anything.
Is there something else I need to remove before removing the HVAC panel or is it a snap on like the shifter panel?
Old Mar 16, 2014 | 09:30 PM
midtowndesi's Avatar
If I recall correctly, you need to remove the panel around the radio first. Just start from one side and pull it towards you. Once that's off, you will see a couple of bolts under the radio/above the hvac and that should be it.
Old Mar 16, 2014 | 09:31 PM
OpTicaL's Avatar
Thanks, took care of the annoying rattle inside last week.
Austin292
Scion tC 1G ICE & Interior
Jan 15, 2015 03:52 AM
Skywalker
13
Jan 29, 2004 11:55 AM
LVXB
9
Jan 22, 2004 11:07 AM
vpkb
12
Oct 8, 2003 04:17 AM
batute
Oct 7, 2003 04:20 AM
