8" in front doors and stealth sub (spare stays).
Old Nov 20, 2007 | 08:14 PM
vettereddie's Avatar
I just want to know, does the window still roll doww, and how far. i ran into this problem with just a 6 1/2" on the 1gen, ended up having to use a spacer ring for clearance.
Old Nov 20, 2007 | 09:28 PM
tylers65's Avatar
You know, I never bothered looking. I suppose I ought to do that before I go spending any money. Thanks for the heads up!
Old Nov 21, 2007 | 08:40 PM
HareBrained's Avatar
Just a word of advice, most "subwoofer" drivers are designed to work within an enclosure (sealed and/or ported). You're looking at an infinite baffle (IB) installation in your door but even then you're not sealing the back side from the front. I would suggest you look at drivers that are the woofer for a set. Dynaudio makes a 3-way set with an 8" woofer. This is designed for this type of installation. MW170
MB Quart, Focal and Diamond offer similar sets/drivers
Old Nov 22, 2007 | 02:24 AM
tylers65's Avatar
The set I am looking at are specifically made for free air applications. I will look into the component set ups as well. Thanks for theinfo.
Old Nov 22, 2007 | 05:03 PM
Madode's Avatar
Since I'm not smart, and using a set of speakers I have from a previous purchase (with filler off ebay) can I ask what may be considered a few dumb questions?
1) For the Sub in the rear, you used an 8" and said a person wouldn't need to use a Shallow sub. Would the same be true for a 10"? Or would I need to purchase the Shallow variant of the 10" sub I like?
2) For the Door Install, are you putting your 8" Woofer in factory 6.5 slot? If not, are you going to use the large plastic area of the door right next to the seat (for instance the driver side door, directly "behind - towards the back of the vehicle" the 1 Liter bottle holder? Could a woofer being used to fill in the sound be placed there? Or does the woofer require air flow or space between the cone(?) and the seat?
3) If I wanted to keep the factory 6.5's in their respective places, and bring in a subwoofer to fill in the lows with the intent to go for Sound Quality; what size of sub would you recommend (I was planning on two 10's or one if I couldn't find a spot that didn't hinder grocery shopping)? I listen primarily to house, hard trance, and rock/alternative. I like bass in my music but don't want to lose the mids and the highs in the process.
Thanks,
Madode
Old Nov 23, 2007 | 05:39 AM
tylers65's Avatar
1) An 8" was used because that is the limit of size to work with in this particular area and it is a tight fit (diameter wise) for most 8" speakers in the cubby where I placed mine. A 10" will not work in this particular spot based on real estate and air space volume needed for the sub to breathe.
2) The Factory 6.5" spots are actually larger than a normal 6.5" hole should be. The speaker is almost too small for the hole. This is with the plastic rings removed. The hole will be trimmed about 3/8" all the way around to to fit the 8" I want to get in there. I personally never recommend cutting holes in areas that are in highly visible areas. To me, cutting holes in the plastic panelling on the door is kind of white trashy. The 8" will fit behind the door panels and no one will be the wiser.
3)It has always been my personal opinion that 10"s are the perfect speaker for those with differing tastes in music. Rock music (again, my opinion) sounds best with 10"s. If you are only looking to augment your factory system, go with a single 10" and about 200W to it and you should be able to hear the bass at low volumes and it will still hit hard enough to overpower the factory system if you so desired.
If you have the upgraded head unit, you can connect an amp directly to it. It sounds decent enough and has the ability to adjust the subwoofer so if it is hitting too much, you can turn it down seperately of the rest of the stereo and vice versa. This will retain everything you hear in your stereo today but will add the low end for you at the same time.
Old Nov 23, 2007 | 02:10 PM
Madode's Avatar
Thanks for the information. I guess I'll need to purchase the upgraded HU, unless the base unit would still work for the time being?
Madode
Old Nov 23, 2007 | 04:01 PM
ScionFred's Avatar
Madode
The base HU will work fine with a sub amp by using speaker level inputs or a line-out-converter (LOC).
Old Nov 26, 2007 | 11:42 AM
pufbox's Avatar
The poor kid in that car seat
Probably feels like mine actually.
Old Nov 29, 2007 | 03:19 AM
tylers65's Avatar
So I have been looking around a bit more and stumbled across a set of Clarion 7" Coaxial Marine Speakers. The dimensions are perfect but I have 2 problems...
They are Clarions
They are for marine (white)
Anyone have experience with Clarion speakers? I can deal with white rather than having to cut up my doors to fit the kicker mid bass speakers in.
Old Nov 30, 2007 | 06:02 PM
speedoguy's Avatar
Team Scionce
very very cool idea, i think i might try making this, but i would want to make the sub fit completely under the rear floor panel, instead of cutting it, but this is the best ideal i have seen so far, good work!
Old Dec 3, 2007 | 02:52 AM
spike443's Avatar
If you're going to run real subs (<80hz) in the back you can get some decent 6.5" woofers with good excursion and low-end roll-off from Parts Express, which'll add some nice punch and take some strain off the front speakers. Tough to make those doors tight enough and solid enough for 8's!
Just my $.02!
Great design , BTW! I'm going to need something that won't take up much space when I get my xB.
Old Jan 5, 2008 | 05:03 PM
randomsuper's Avatar
this is a great idea! i'm gonna see if i can have someone fab up something for me out of fiberglass. how does it sound and did you end up tweaking it at all?
DaBlackBox
134
Apr 10, 2022 02:04 PM
VCUBoy714
Scion tC 1G ICE & Interior
Jan 5, 2015 08:46 PM
DibujoB
14
Nov 21, 2003 12:26 PM
shaefner
Oct 8, 2003 02:48 PM
