Drill sizes for C-pillar storage install?
Old 02-24-2011, 12:06 AM
TrevorS's Avatar
Default Drill sizes for C-pillar storage install?
Just picked up one of those C-pillar storage kits from TRDsparks and the listed drill sizes are just a little mysterious. Anybody happen to know how they translate in to standard drill sizes (o4 drill bit, o15 hole saw)?
http://www.trdsparks.com/install/08446-12800inst.pdf
TrevorS is offline
Old 02-24-2011, 01:46 AM
KaneoheKoa's Avatar
Coming from Scion, it looks like metric bit sizes. 4mm is .1578 inches, so a 5/32" bit will do. The 15mm (.59") is close to 9/16" (.5625"), or if you can find it, a 19/32".
KaneoheKoa is offline
Old 02-25-2011, 07:31 PM
TrevorS's Avatar
Whoa, that signifies metric does it -- had me going ! Thanks !
TrevorS is offline
Old 02-27-2011, 11:02 PM
TrevorS's Avatar
Looked around for a 9/16 or 19/32 and found the standard local suppliers stop at 1/2". Sears Hardware has a 9/16" but it costs $20, and I wasn't about to spend that. I finally just compared the plastic posts on the back of the cubby frames to my supply of drill bits and found 15/32" fits it.
So, after marking the template holes with an awl, I drilled 5/32" pilot holes, and then applied the 15/32" for the posts. However, it turned out my hole centers were slightly out relative to the posts and so I slightly enlarged the holes by carefully rocking the bit in the offending directions. Ended up taking me longer than expected and have blisters on my palm from tightening/loosening/tightening/etc the screws, but it's done and seems solid (frames fully back in the recesses, screws fully tightened.) I think if I'd drilled with a 1/2" with built in pilot point, it would have sped things up considerably, but in any case, there's no need to pay lofty prices for the "correct" drill, a little patience and care will still get you there !
TrevorS is offline
Old 02-28-2011, 04:16 AM
KaneoheKoa's Avatar
I feel your pain about $$$ drill bits. Being a woodworker, I have to endure $60 router bits. As for those odd hole sizes, I picked up a 3-bit step drill set. They are the absolute best for drilling plastic or metal, as they leave a very clean hole. They also don't jerk through the hole like regular twist drills do upon breakthrough. Harbor Freight has them for cheap. The really good stuff (Klein and others) cost 4x as much. They last longer, but for occasional use, the HF stuff works well.
Old 02-28-2011, 11:58 PM
TrevorS's Avatar
Ha! So that's what those stepped drill bits are for ! I just put together a tiny basement wood shop last Fall and have made a few visits to Harbor Freight (bought an OSS from them Jan 1 ). Always wondered about those sets, and now see I should have moved on one -- thanks again !
TrevorS is offline
Old 03-01-2011, 02:19 AM
mnscionxb's Avatar
got mine at home depot
mnscionxb is offline
Old 03-02-2011, 01:56 AM
TrevorS's Avatar
BTW -- Those storage units really do look like they belong in there. The full list price is a little hard to swallow, but TRDsparks half-price is pretty reasonable. If you don't have some other purpose in mind for those two alcoves, I'd say it's a very reasonable way to go ! (Only took me three years to pull that trigger .)
TrevorS is offline
George
Regional - Pacific South
200
02-11-2006 01:48 PM
Genesis
64
01-22-2005 01:02 PM
TheRedBox
31
12-02-2003 04:53 PM
scionlife
04-16-2003 05:13 PM
Quick Reply: Drill sizes for C-pillar storage install?
