Help. 2008xb inputs and steering wheel remote
Old Oct 5, 2013 | 10:24 PM
markbrickens's Avatar
Default Help. 2008xb inputs and steering wheel remote
I bought a 2008 Scion xb and the center console Ipod, Aux inputs and Steering Wheel remote didn't work. I took out the 1808 radio and found that the connectors and been cut off and capped. I am trying to find out what cables, interface? and sat radio to use. I would like to use factory equipment. I also looking for a wiring diagram that shows all those connections. All I can find is the basic power and 4 speaker diagram.
Please help.
Old Oct 5, 2013 | 10:32 PM
Greg S's Avatar
Does the car have a factory radio in it at this point. It sounds like it had an aftermarket and the cable were all cut to make some room in the dash. At this point it might be a lot easier to get and aftermarket radio and just route the inputs to the stock locations is you want to still use them. i did that with mine so that I had a USB plug instead of just an Ipod jack and the sat radio is built in to the new headunit.
Old Oct 5, 2013 | 10:45 PM
I may end up doing that if I can find any alternatives. I still need to find the steering wheel connection if it is somewhere other than the stereo area and not been cut off.
Old Oct 11, 2013 | 03:15 AM
TrevorS's Avatar
Here's the OE 2008 head unit connector information I put together when working on mine, C27 has the SW controls. Good luck!
Connector C1(10) has power and front speakers:
1 - FR+
2 - FL+
<gap>
3 - ACC (7.5A fuse)
4 - BAT (15A fuse) Light Green
<next row>
5 - FR-
6 - FL-
7 - GND
8 - POWER ANTENNA
9 - POWER AMP
10 - ILL+ (+12V illumination) Green
Connector C2(6) has rear speakers:
1 - RR+
2 - RL+
3 - RR-
4 -
5 - ILL- (Dimmed illimination) White
6 - RL-
Connector C27(20) has Steering Wheel Pad & AUX; "CIPOD"(16) has IPOD, "CLAN"(12) has LAN. The PAC SWI-JACK identifies three C27 pins:
"C27" (2.2mm/.0866" pitch, 3.0mm/.1181" row spacing)
1 - nc
2 - nc
3 - Purple (SPD - vehicle speed signal)
4 - nc
5 - nc
6 - Black (SWG - steering wheel controls ground)
7 - White (SW1 - steering wheel controls input "1")
8 - Red (SW2 - steering wheel controls input "2")
9 - nc
10 - nc
<next row>
11 - nc
12 - nc
13 - nc
14 - Gray (AUXG - aux ground)
15 - White (ARI - aux right input)
16 - Green (ASGN - aux shield)
17 - Black (ALI - aux left input)
18 - nc
19 - Yellow (AUXI - ???)
20 - nc
"CIPOD" (2.2mm/.0866" pitch, 3.0mm/.1181" row spacing)
1 - Red (FWGD - FireWire ground)
2 - nc
3 - Green (ACID - Accessory ID)
<gap>
4 - Blue (FWPW - FireWire power +12V)
5 - nc
<next row>
6 - Orange (ACPW - Accessory power +3.3V?)
7 - (black taped pair) (DOGD - IPOD serial ground)
8 - White (DOTX - IPOD serial from IPOD)
9 - Black (DORX - IPOD serial to IPOD)
10 - Yellow (ACDT - for charging signal???)
11 - White (ADUL - IPOD audio left)
12 - Black (ADUR - IPOD audio right)
13 - (black taped pair) (AGND - IPOD audio ground)
14 - Pink (DGND - IPOD ground)
15 - nc
16 - Purple (JGND - IPOD shield?)
fur_pig
Mar 20, 2020 04:28 PM
toyotaisme
Jan 10, 2015 10:24 PM
Beesh
Jan 9, 2015 06:30 PM
