Help removing cluster...
well if you are referring to the tC cluster it is easy.
1. Adjust the steering wheel all the way down.
2. Pull bezel off, it snaps into place so it will pop off.
3. Remove philips screw at the 12 o'clock postion on the cluster.
4. Pull cluster out.
The dash cover in front of the gauges just pop's out, Than there are 4 or 5 bolts holding the gauge cluster. Once bolts are removed pull cluster out and remove plastic cover to gauges. I know there is a post on this, i will try and find it.
This thread is for LED Swop on the gauges , But gives you the idea on how to remove the cluster.
https://www.scionlife.com/forums/sho...ighlight=gauge
Hope this helps
Hope this helps
Sgtfluffy16
Regional - Northeast
Jul 28, 2021 10:32 PM
steeze69
May 24, 2021 02:57 AM
