Installing PT546-00121 to a 2008 xB
Old Jan 24, 2020 | 10:51 PM
alexjl's Avatar
Default Installing PT546-00121 to a 2008 xB
My radio function is operational. I want to be able to install a USB port that would connect to the head and have the steering controls operate the volume, mode and stations/tracks.
Of course the harness females that come from the car have different number of pins than the ones on the head.
I could fabricate mine if I had the key to the cables and a male to connect to the car and a female to connect to the head.
Is there anyone that fabricates the harness to convert?
Of course I need the harness to connect to the USB on the head and a conversion harness to the USB.
Also need to add microphone for the Bluetooth function.
Does anyone have a solution to this?
Sticky How To Advanced Search SL (Scion Life)
______________________________
Last edited by MR_LUV; Jan 25, 2020 at 12:25 AM. Reason: Moved to Correct Forum by Administrator
Old Jan 27, 2020 | 05:16 PM
Greg S's Avatar
The USB harness in the 08 xB was never designed to support two way functionality, it was for basic playback of an old school iPod. You would need to get the one that is designed for this head unit and replace the original one in the car. I'm not sure on what microphone you would need to use, quite possible that you would need the stock one for this head unit as well depending on the harness for it. I just went to route of replacing the stock radio with an after market that had all of this built in and getting a steering wheel control adapter for it.
Old Jan 27, 2020 | 10:00 PM
alexjl's Avatar
Thanks Greg. For now I've decided to not invest in an aftermarket radio. That is what I did to the 2012 the radio came from. So this is a transplant from that car.
Dave90T
123
Nov 22, 2014 01:05 AM
Mattk65
Scion tC 2G ICE & Interior
Aug 8, 2011 01:21 PM
Rabid_Lemming
Scion tC 1G ICE & Interior
Apr 13, 2007 08:21 PM
Rits399
Mar 27, 2005 01:18 AM
TheInfamousSofa
Mar 7, 2005 06:49 AM
