Painting the trim pieces
Old Mar 2, 2008 | 01:29 AM
Ray18's Avatar
Default Painting the trim pieces
Can any one give me tips on how to paint the gray trim piece's idk how dont even have the minor idea on how 2 i got some spray can and clear but do i need 2 sand down heat up u tell me
Old Mar 2, 2008 | 01:32 AM
MooseMobile's Avatar
I'd like to see a little mini DIY as well... I would like to paint mine purple.
Old Mar 2, 2008 | 04:38 AM
miketf1's Avatar
damn if you asked this question yesterday i would have made a DIY. right now they are drying...
if you know how to remove the pieces then its quite simple. sand with 320grit and smooth out the surface. dont half ___ this. 80% of painting is preparation then paint in light coats and wait 10mins between coats. so far i have about 7 layers and getting ready for a final coat and then clear coat.
good luck!
Old Mar 2, 2008 | 05:57 AM
xbean's Avatar
hmmm sanding must be important becasue thats what i missed....
any advice on removal of the paint?
Old Mar 2, 2008 | 02:25 PM
toolz's Avatar
sandpaper
Old Mar 2, 2008 | 02:53 PM
xbean's Avatar
sandpaper
what kind? i dont wanna mess anything up.....
Old Mar 2, 2008 | 04:24 PM
silverx's Avatar
any DIY on how to remove the trim pieces?
Old Mar 2, 2008 | 04:26 PM
Ray18's Avatar
Do i heat up the pieces or not because i painted some and then i waited but when i scratch it with my nails the paint comes off
Old Mar 2, 2008 | 04:41 PM
chadfo's Avatar
I woulnd't recommend heat. They are just plastic. Even though paint may be dry to the touch it still needs plenty of time to fully cure and harden.
Old Mar 2, 2008 | 04:44 PM
Ray18's Avatar
So how long should i let them dry and how do i know that im using the right sand paper
Old Mar 2, 2008 | 04:47 PM
xbean's Avatar
DIY = pull....
...no really
Old Mar 2, 2008 | 04:52 PM
lvbitwiz's Avatar
Read the can, some cure in as little as an hour, some take a week to cure
Old Mar 2, 2008 | 04:54 PM
coryjames's Avatar
and use crylon fusion for plastic or the paint wont stick for long
Old Mar 2, 2008 | 05:11 PM
Ray18's Avatar
What is that crylon fusion well i went to home depot and bought paint for plastic
Old Mar 2, 2008 | 05:17 PM
coryjames's Avatar
thats usually the stuff just make sure you let it dry for a long time
Old Mar 2, 2008 | 05:21 PM
07tctul's Avatar
if i decided to use a plastic primer, would it still matter if i didnt use plastic paint?
Old Mar 2, 2008 | 05:22 PM
coryjames's Avatar
i would use the plastic paint anyways plastic is hard to paint good
Old Mar 2, 2008 | 08:15 PM
MikeInABox's Avatar
You may not have let it dry long enough. But if you did and that happened, you may not have had the part clean enough. You need to make sure it's all really clean as even oil from you skin can cause some problems. It could also have been if you put too heavy of a coat on and on the surface it felt dry but there was a lot of wet paint underneath. That's why several light coats are the way to go. Heavy coats rarely produce good results.
For general spray can tips you can search online. I saw a write up that a model car builder did with pics, his end results were smooth as glass. And the techniques used are basically the same.
Old Mar 2, 2008 | 08:59 PM
miketf1's Avatar
dont heat the plastic. it comes off that easy cause you didnt prep the surface. gotta sand it with 320grit. then you can use plastic primer then paint or straight to krylon fusion.
between coats about 15min dry time. then let it sit for at least 24 hours.
your should stick with the same brand of paint so that the paint wouldnt react improperly.
Old Mar 2, 2008 | 10:04 PM
xbean's Avatar
so let me get this right...ive already tried and failed horribly at this.
i already have a few layers on the pieces but i wanna start over.
so i sand down the crappy paint, paint light coats, finish with clear...
right?
