Painting the trim pieces
Old Mar 2, 2008 | 10:14 PM
Whispaz's Avatar
correct. or you can just paint over all the old layers but i'd sand for it to adhere better
Old Mar 2, 2008 | 10:45 PM
xbean's Avatar
ya...i tired to paint over but it looks even worse...
what kind of paper should i get?
Old Mar 2, 2008 | 11:18 PM
Whispaz's Avatar
hmmm..... I'd just get the assorted pack of sandpaper. that way you can sand with 800-1000. whatever feels better. i cant think right now
Old Mar 2, 2008 | 11:19 PM
chadfo's Avatar
Soak the parts in brake fluid. It will remove the paint without hurting the plastic. Depending on the paint it could take up to a week for it to come off. Better slow than damaged.
For sandpaper I recommend using 400 or maybe 600 grit that is water resistant. The paper will last longer and the surface usually comes out smoother when wet sanding.
If you use Fusion paint, you don't have to prime. For any other paint find a good primer and be sure to wet sand before painting for a smooth surface.
Old Mar 2, 2008 | 11:25 PM
xbean's Avatar
do i have to remove the paint first before paining again? or can i just sand down to a smooth surface?
Old Mar 2, 2008 | 11:46 PM
chadfo's Avatar
It depends on your first paint job. If it just looks bad but is well adhered, you can just sand smooth and repaint. If you are unsure or if it's easy to scratch, take it back to bare plastic. Good paint over bad paint equals a short life for your good paint and having to start over. It's better to take the time to do it right now then to have to redo it all over again later.
Old Mar 3, 2008 | 04:38 AM
xseveredveganx's Avatar
Utah Scions
I'd recommend wet sanding whatever you want painted with some 500grit. I've done it before on other cars... It's not that hard. But then again, I was using automotive paint...
If you want to paint something with a texture, and do not want that texture, then of course you'll have to sand off the texture. After sanding off the texture, I'd recommend a prime and guidecoat. It all depends on how you want the final result to be.
But 500grit wet. If I do any parts on my car, that's what I'll do. Just enough of a sand so water won't glide off of and it's not glossy. It'll give the paint a tooth to adhere to.
Old Mar 3, 2008 | 12:47 PM
DJ_FroZone's Avatar
wet sanding means make it wet then sand?
Old Mar 3, 2008 | 03:21 PM
Whispaz's Avatar
yup, sanding while it's wet.
Old Mar 3, 2008 | 03:25 PM
faux_ghost's Avatar
i used to have a DIY from when I done mine, it was on another site though...i think its gone now
Old Mar 3, 2008 | 05:07 PM
DJ_FroZone's Avatar
sooooo awesome
Old Mar 3, 2008 | 05:18 PM
faux_ghost's Avatar
Here are the steps I took:
sand with 800 grit
wet sand with 1000 grit
dip in distilled water bath, wipe down with clean rag
spray 2 coats of plastic adhesion promoter
plastic primer
4 coats of base white
wet sand with 2000 grit
distilled water bath and wipe down
6 coats of pearl white
4 coats of clear coat
install and be amazed
Old Mar 3, 2008 | 06:27 PM
xbean's Avatar
heres my steps...
-paint with krylon plastic paint
-dry
-fail miserably
-have a fit
-wonder where to go from there....
any ideas?
Old Mar 3, 2008 | 06:30 PM
coryjames's Avatar
um get some say 320 grit sand it down go light on corners take your time with lighter coats its not really that hard just got to be patient
Old Mar 3, 2008 | 06:36 PM
xbean's Avatar
idk y but the paint i got is not adhering to the plastic no matter what i do. its frustrating........
whats the best paint to use? im using krylon plastic paint
Old Mar 3, 2008 | 06:58 PM
faux_ghost's Avatar
use the model car spray paint, mine is House of Kolors
Old Mar 4, 2008 | 12:03 AM
lvbitwiz's Avatar
inside trim duplicolor metalcast
light sanding w/320
clean clean clean
coat of adhesion promoter (per direction on the can)
light coats of metalcast 'groundcoat'
let dry per package
light coats of metalcast blue
let cure for about a week
duplicolor clear
underhood
light sand w320
clean clean clean
light coats of krylon fusion blue
krylon clear
apply randodes chrome lettering
after almost 6 months no peeling, cracking etc...
Old Mar 4, 2008 | 12:06 AM
lvbitwiz's Avatar
Originally Posted by xbean
heres my steps...
-dry
-fail miserably
-have a fit
any ideas?
do the brake fluid and get back to a clean surface.
Old Mar 4, 2008 | 12:28 AM
DJ_FroZone's Avatar
light sanding w/320
clean clean clean
let dry per package
duplicolor clear
underhood
light sand w320
clean clean clean
krylon clear
u have done excatly what i want to do. to the excat point. show me the ways. what color. whats curing?? teach me master
Old Mar 4, 2008 | 03:47 AM
Ray18's Avatar
Hey thanks guys well i used some plastic parts 2 practice on and those where the one's that i said when i put my nail on it they would scratch well i sanded one and the other i just painted over
Well right now after 2 days i tried again 2 scratch the one that i didnt sand did scratch but the one that i did sand down did scratch now i know what ima be doing for spring break lol
