What is this button?
Hi everyone!
I have a 2008 Scion xB that I got back in January. I LOVE this car!! Question- what is this button to the left of the gear shift? It doesn't have a face plate on it, so I have no idea.
I have looked at the owners manual and haven't found anything. I have attached a pic in the hopes that someone can help. Thanks!!
[img]webkit-fake-url://9b2f516f-ce5b-4fc7-ba0c-0ef68c9ff786/imagejpeg[/img]
Last edited by MR_LUV; Sep 9, 2017 at 01:29 AM. Reason: moved to correct forum and typo
Hi everyone!
Obxtess,
Your question is now Moved to the Correct Forum.
You need to Repost your pic:
How to Post Pictures on Scion Life (SL)
Moderator
You are probably referring to the shift interlock button. If your shifter ever gets stuck and won't move, here is the procedure:
"Put the emergency brake on. Find the shifter lock override slot, which is usually located on the shifter console close to the shift lever. The slot will be plugged with a plastic cap. Remove the cap and push down on the button with a nail file or other pointed object."
Hope this helps.
Hope this helps.
