Where can I find a 2008 xB wiring diagram?
I'm working on installing Rumion sillguards and the Japanese instructions are definitely different from those for the 2008 Scion xB illuminated sillguards. Since the connector specifics appear to be inconsistent between the two vehicles, I'm hoping to find the xB2 wiring diagram. Anbody know of a source?
Thanks -- Trevor
Thanks -- Trevor
I dont have an answer to your question, BUT I do have this for you.. if you havent seen it, it may help you out.. If you feel adventerous. If I had those reumion ones, I would use this as a template as best as I could.. ...
http://www.trdsparks.com/install/00016-79810inst.pdf
I put mine (SCION ones, NOT RUMION) in using this diagram.. It may help you mabey not......
Also. try looking here..........
http://www.fsu-clan.com/scion/
good luck.. jh
good luck.. jh
good luck.. jh
good luck.. jh
! I downloaded the Sparks PDF earlier, that's how I decided the two were different. However, the differences I'm seeing are just on the left side (Driver's for Scion, Passenger's for Rumion.) I suspect the Scion has a nicer solution available for the Driver's side door open switch (B-Pillar white wire), than feeding back to the switch, but I'd need the diagram to identify the appropriate junction connection -- it's different from the Rumion. However, with the exception of the Rumion kit actually providing a +12V harness, the right side wiring is identical.
SuperXero
Scion tC 1G ICE & Interior
Feb 23, 2020 08:17 AM
NewBox06
Feb 3, 2015 12:36 PM
DynamiteSJ
10
Nov 2, 2003 01:25 AM
