Best way to clean under the hood?
Anyone clean out under the hood? Someone told me if I cover the electrical parts with plastic wrap I can shoot down the inside with a power washer and TSP. They also recommended this for under the car, as that is pretty dirty/dusty also...
Any suggestions/Ideas?
Thanks!
Thanks!
Get some plastic grocery bags and enough rubber bands to tie what you need and want covered.
I did it to my camaro before I sold it I covered the
fuse box
oil cap
tranny fluid cap
brake fluid
You can try and cover ignition cables that are behind the engine cover
Just try and cover as good as you can any electric wiring especially the connections you should be good
make sure if you pressure wash it that if you engine is hot or warm let it cool down. I've heard you can crack the engine block if your engine is to hot. it really doesnt seem likely to crack ur block just by that. I let mine cool down b4, better to be safe than sorry.
fuse box
oil cap
tranny fluid cap
brake fluid
Cool water + hot block = probably not a good idea. Let the engine cool down before you do it. It'll also help keep down on the water spotting. When I washed my engine compartment, I just used my wash mitt after I finished the body, and used a gentle stream of water, keeping as much water as possible away from the electronic bits. Its made to be relatively water resistant, but if you're going to be pressure washing, then thats a different story...
ive always washed my cars the same way: dont cover anything lol, do this before you go to bed or at a time when you can let it all dry for a while.
use all of 1 can of foaming stuff used for engine bays at autozone, let it sit for about 5-10 minutes then spray it down with a hose. nothing has ever happened to my cars doing it this way.
but i have never used high pressure. all of the stuff under there is sealed pretty good for harsh weather conditions, so i wouldnt worry about low pressure water.
I just use my shammy when I am done washing the rest of my car and wipe it down good. I do like the simple green idea, but since I typically clean my car up and down once a week during summer, that wont be neccessary. That would work great when cleaning the car for the first time after winter!! GREAT IDEAS!!
Luisfc1972
Sep 30, 2015 12:22 PM
