brightest solution for replacement back-up light (7440 bulb)
Old Dec 2, 2008 | 02:47 AM
  #281
cobb's Avatar
Can the reverse socket take a load of 20 amps surge? If so, I have 2 3000k h11 bulbs and ballasts laying around.
Originally Posted by marcemarcxB08
http://www.youtube.com/watch?v=Gf-M-BjJiZo
Old Jan 14, 2009 | 05:36 PM
  #282
AlaricD's Avatar
Originally Posted by paxber
Think incendescent light fixture in your house . You may have a fixture with 4 -40 watt bulbs. It is still 40 watts of light power generated,but it covers a wider,larger area of 40 watts of light{lumens}. Unscrew 2 bulbs,you still have 40watts,but the area around you appears dimmer,except when you look directly at the remaining 2 bulbs,you still have 40 watts.
An incandescent fixture with four 40W bulbs installed will consume 160W of power. It will emit approximately 1960 lumens, as each 40W bulb will emit about 490 lumens (data for a 40W "soft white" bulb). Yes, unscrewing 2 bulbs will make the area appear dimmer, but this is because you will be consuming only 80W of electricity and outputting 980 lumens.
Lumens {simple terms}is the measure of light generated,per watt .
Lumens is the measure of the perceived power of light. Luminous efficacy is the measure of lumens generated per watt consumed. A 40W "soft white" incandescent bulb emits 40 lumens of light, and has a luminous efficacy of 12.25 lumens per watt (490/40). A typical 40W fluorescent tube emits about 2150 lumens, giving it a luminous efficacy of 53.75 lumens per watt.
Old Jul 28, 2009 | 04:25 PM
  #283
DJ_FroZone's Avatar
Originally Posted by jimmbomb
Well People.. I stumbled across this............
https://www.scionlife.com/forums/viewtopic.php?t=209510&highlight=wiring+diagram
It details a ''HOW TO'' re-wire your LED tails so that the "BRAKE LIGHT" section ALSO functions as the "TURN SIGNAL" function.. So the brake light section will light up when the brakes are applied & EITHER side will flash when the turn-sigs are applied.. ALL in the same SECTION of the light assembly....
You know what that does??
That frees-up the TURN SIGNAL SCETION to do what ever you like...
In this case... HE swapped out the amber incandecents for WHITE bulbs in the TURN SIGAL 'section'...THEN wired the old 'tun-sig section' to his REVERSE lights....
NOW in this case this was an xB1.... & he now has 4 reverse light bulbs burning when he puts it into reverse.. (check out the videos!!!)......
in OUR case,(provided that you have aftermarkert or SCION LED TAILS)
You would end up with 3 reverse lights....
1) your existing single in the bumper &
2) & 3), your new reverse lights where your turn signal once were...
WHILE still maintaing your turn-signals, only re-located......
Pretty freegin Slick...........
https://www.scionlife.com/forums/vie...wiring+diagram
Now..anyone living close to St Louis wanna help me do mine?? I'll be the guinia pig for this project, but I wont do it alone.. I want help....
jh
can we get a reup?
Old Oct 30, 2025 | 01:52 PM
  #284
Robswafford's Avatar
Default Solution to backup light on the scion Xb
Originally Posted by MauiGideon
Anyone get a solution 2 this yet?
I went thru several bulbs and finally found this one. If anything it might be to brite, (if thats even possible}. Its brite enough that I can clearly see on all sides from all mirrors.
600% Super Bright 4000 Lumen White for Back Up Reverse Lights, 7443
Delivered on Tue, Oct 21
Returns accepted through Nov 4.
US $43.89
Sold by:
ireallylokeyou
tato63
Scion tC 2G Wheel & Tire
9
Sep 30, 2015 09:55 PM
torranosaurus
Jan 28, 2015 04:53 AM
scsteven
Jan 25, 2015 01:06 AM
jaspercanda
Dec 28, 2014 10:09 AM
dgm458
Scion xD Drivetrain & Power
Dec 7, 2014 05:59 PM
