Epidemic Water Pump Problem!
Old Jun 22, 2011 | 05:32 AM
  #241
TrevorS's Avatar
Originally Posted by SamCarroll
They redesigned the pump and when a faulty one shows up they replace it with the newly redesigned one.
If they redesigned the pump (as in for real), why isn't there a new part number for the corrected pump? If I'm overlooking something, please point it out !
Old Jun 26, 2011 | 06:02 PM
  #242
YELOSUB's Avatar
Wagonistas
Has this issue been fixed with the 2010 models?
Old Jul 3, 2011 | 05:37 AM
  #243
azylstra's Avatar
I did the same thing and got the same response. Fluctuating with temperature is one thing, going down is something completely different. The only conclusion I can draw is that the fluid evaporates over time. Maybe if you have it documented that you took it in before the warranty was up and it leaks after the warranty expires, they might cover it.
Originally Posted by Invertalon
I about to take mine to the dealer again... I took it in the first time last year because of lower coolant and they said there was no leak and the fluid level fluctuates with temp... So they topped it off and now either hot or cold, the coolant as at or below the low level again. No pink line, but something is going on.
I am at 56,000 miles, so got to get it in there soon!
Old Jul 13, 2011 | 05:24 AM
  #244
r2d2michael's Avatar
i took my 09 xb in for bad coils and pointed out the coolant level. told them to check water pump. they did and found pink crusts on it. first they said they wont fix its because its not leaking enough lol. i called bull____ and they fixed it. i was 4 inches below the low mark with 30k miles on it...if thats not leaking them im a ice cream sandwitch...
Old Jul 19, 2011 | 01:18 AM
  #245
Invertalon's Avatar
I bought some coolant and topped mine off the other day... Last time I took it in was two years ago for low coolant, and they found no leak. Prob just evaporation on mine. It only took a small amount of fluid to top off, very small.
I still want to look around though before I hit 60K, just in case. No pink line though, or no leaks I have seen.
Old Aug 4, 2011 | 12:31 AM
  #246
DREWxB08's Avatar
Well my xB is now 4 years old and has 26,xxx miles and today the water pump and thermostat were replaced along with an oil change. Pump was covered but the thermostat was not. Just glad its fixxed and also hope the VSC, traction control and check engine light don't go back on. If so the n the MAF has to be replaced.
Old Aug 4, 2011 | 01:00 AM
  #247
ScionFred's Avatar
If you're getting a P0101 code for "MAF out of range" it can be caused by a CAI or other intake mods. It doesn't necessarily mean that the MAS needs to be replaced, although a dealer mechanic might think so.
If you do think your MAS is bad, try cleaning it first. Most auto parts stores sell MAS cleaner for about $5 a can. It's worth a shot.
On topic, I finally have the coolant line on my hood after 47k miles. What a great water pump! It's a very slow leak at this time but I imagine it will only get worse. I wonder if a water pump lube additive might help. Might try it.
As for a part # change for an improved water pump, there may not be one. If the supplier simply changed the seal material or design of the pump they wouldn't necessarily change the part #. Same pump, new seal, same number.
Old Aug 4, 2011 | 01:42 AM
  #248
TrevorS's Avatar
I'm just approaching 10K and the thing that concerns me is Toyota may have decided conversion to the 2AR-FE water pump may be an adequate solution to the 2AZ-FE pump problem. However, it's not clear they're compatible, and there's no indication the current 2AZ-FE pump incorporates a fix for the well reported problem.
Old Aug 4, 2011 | 02:01 AM
  #249
LED-Maniac's Avatar
take off your radiator oil filler cap, if it looks like a chocolate milk shake...you need a head gasket
Old Aug 4, 2011 | 02:04 AM
  #250
TrevorS's Avatar
I'm not clear anyone has had that problem, have you?
Old Aug 5, 2011 | 01:23 AM
  #251
LED-Maniac's Avatar
nope, its just your typical sign of a blown gasket.....but so is smelling coolant when running in the exhaust. Sounds to me more like a coolant leak.
Old Aug 5, 2011 | 05:31 PM
  #252
TrevorS's Avatar
Well, a pink line on the hood liner above the water pump is pretty unlikely to have anything to do with a head gasket. That's the symptom of the problem being discussed in this thread.
Old Aug 5, 2011 | 11:27 PM
  #253
masterbB's Avatar
i own a 08 with just 30,000. had a new water pump, head, head gasket, etc. replaced under warranty at 25,000. Now at 30k my engine is knocking, so guess what, entire new engine under warranty. lets see if this one lasts
Old Aug 5, 2011 | 11:49 PM
  #254
TrevorS's Avatar
Jeez! What happened to it back then?
Old Aug 6, 2011 | 02:06 AM
  #255
masterbB's Avatar
idk, the head was bent im guessing from overheating due to the failed water pump...
Old Aug 6, 2011 | 03:50 AM
  #256
TrevorS's Avatar
Oh yeah, overheating can easily warp an aluminum head (happened to me before on a Honda Civic), can result in coolant leaking into the oil, and thereby screwing up various engine bearings. Major drag dude !
Old Aug 9, 2011 | 08:51 PM
  #257
Schmohey's Avatar
Anybody attempted doing this out of warranty? My xb is out of warranty and the pink line is getting more "severe" than what it was half a year ago. For those who took it to the dealer, how many hours did the job take?
Old Aug 25, 2011 | 11:35 AM
  #258
trixie_storm's Avatar
I just had mine done at the dealership this week. Took them 3 hours. Mine was under warranty: 2008 at 46k miles. Be aware that they do not keep them in stock so you should ensure it is ordered prior to your visit.
Old Aug 25, 2011 | 02:12 PM
  #259
i had that line on my xb2 after 5000 lol never thought it was the pump about it intell now. i always thought it was junk from the road hitting the belts and flying up on the hood. good to know!
Old Aug 25, 2011 | 03:34 PM
  #260
ROCKLANDTOYOTA's Avatar
maybe your dealer BUT we always have a supply of pumps for ALL toyota's....
