Factory NAV system fix needed
I purchased my 08 Silver 5spd with the NAV system a few days ago. I am used to a portable Garmin unit. I am very surprised that the Scion system does not allow you to access almost all of the nav functions when you are moving. This, I believe, negates a lot of the advantages of a nav system. Today, my wife and I were driving the freeway. It was lunchtime, and we wanted to look for restaurants on the nav unit. Sorry...you can't input a route while you are moving!
Is there a fix for this? I suspect that the unit must be wired into the Vehicle Speed Sensor somehow.
I was really looking forward to having a permanent nav unit in the xB. However, the way it works from the factory, the portable Garmin unit is far superior!
Thanks!
Kevin
Thanks!
Kevin
I have a 2007 Yukon Denali. with a Nav system and it also does not allow you to do anything while the car is moving. This is all thanks to lawyers. I sure someone comes up with a hack because I've got my Blackberry Crush metallic coming in 2 weeks and I want a useful Nav system not something that only works when its stopped.
I searched all of the posts on this site prior to my purchase. Although I did read criticism of the price of the NAV system, I didn't see any posts that mentioned that the factory NAV system was disabled. Had I known that, I would not have purchased the factory system.
I think that there is a great money-making opportunity for someone to come up with a fix for this!
Kevin
Kevin
Well legally any navi that goes in place of the radio will be "disabled" like that. For my navi (Eclipse AVN5435) I just had to ground out the parking brake wire to the metal frame where the radio attaches and I can do anything while driving, sure in the info screen it says parking brake on, but it doesn't hinder beyond that.
However the difficult part is that unless it has a seperate harness for the parking brake, reverse.... there may not be an easy way around it. If it was a seperate wire, you could just ground it out.
Legally they cant sell a car with navi without having that "safety feature"
I think I read in one of the manuals that the NAV was disabled at 12mph. That makes me think that it is somehow tied into the Vehicle Speed Sensor.
The manual also mentions that the parking brake must be on to view DVDs.
Kevin
Kevin
I am future XB owner and am debating on ordering the Nav system but can't see any benefits from it unless you can disable the lock out. So I did some research and found this website for the Prius's NAV system to disable the lock out, now what I have been told it is the same steps for the New XB's Nav system. Please try it and let me know if it works so I know if it's worth ordering the Nav sytem myself. I would greatly apprciate any feedback on it.. the website for instructions is... http://www.wikihow.com/Override-Toyo...ation-Gray-out
ok, to watch dvd's without the ebrake on, ground the red wire under the console to the bolt that holds the console to the floor.
Theres a green wire running over to the fuse block behind the dash just left of the steering wheel. Cut this wire.
Behind the navigation, look for a plug in the back of the nav with a yellow, green, a couple white, a couple black, purple, and a few other wires (from memory, theres probably about 8n wires in this plug). Cut the purple wire and extend the wires over to one of the empty switch locations. I used a rocker switch from a scion led interior kit. Install the switch in the dash.
Now you can flip the switch off to watch dvd's or to type the nav keyboard.
The nav map will not track your movement when the switch is off, so after you are done typing, flip the switch back on and it will resume navigating.
now who's your daddy?
great description randode. thanks! also, i would have ordered an interior LED kit from you had i found you first, but hence, i have the factory installed now... it would be easy to switch them out, no? where can i get a "rocker" switch for the dvd nav mod? thanks!
yes you can enter the POI as long as the switch is off.
still trying to source out a switch that fits and looks factory.
I like how Scion changes the switch size just to mess with me.
