First Oil Change?
Old Aug 19, 2008 | 12:20 AM
prelude622's Avatar
Default First Oil Change?
I was wondering at what miles should I do my first oil change............I plan on switching to synthetic.
Any advice is appreciated
Old Aug 19, 2008 | 12:49 AM
Setiri's Avatar
If you just bought your xB2 then it should already have synthetic in it and you won't need to change your oil till 5,000 miles. That's the recomended mileage anyway.
A lot of people however will tell you that at your 1,000 mile mark, change the oil. Then get on a regular schedule (if you're sticking with synthetic, that'd be every 5,000 miles). The reason for the first change at 1,000 miles is to clear out any possible metal shavings that may be left after the engine's first break-in period. This is arguable though as Scion and most car manufacturers these days supposedly break in the engine relatively well in the first place and there shouldn't be a need to do it yourself... but we're all entitled to our own opinions.
If ya got the time and money, change it at 1,000 and get on a schedule of every 5,000 after that... if you don't have the money to spend on a possibly helpful/possibly meaningless $45'ish oil change, go for it.
Old Aug 19, 2008 | 03:42 AM
buickid's Avatar
I just changed the filter at 500 miles. I cut it open, and it was kinda sparkly, so I'm glad I did. Wix replacement filter ftw.
Old Aug 19, 2008 | 05:39 AM
BBN-Boys's Avatar
Jyust wondering....
What brand oil and grade did you use? Synthetic?
Old Aug 19, 2008 | 07:49 AM
808-213-503's Avatar
It says 5000 miles OR 6 months. I went 10 months before I hit 4400, and you could feel the engine wanting new oil. I think 6 months would have been perfect.
I'm going to go with 6 months, which means about every 2500~3000 miles.
Old Aug 19, 2008 | 09:15 AM
buickid's Avatar
Jyust wondering....
Didn't change the oil, just changed the filter. The oil is still good, but the filters is whats keeping it clean and collecting a lot of the metal bits. (As evidenced by the sparkly bits in the filter oil)
Old Aug 19, 2008 | 03:12 PM
AAG's Avatar
AAG
DeepSouth Scions
I changed mine out at 2k miles and since then have been doing 5k OCI.
Old Aug 19, 2008 | 04:08 PM
prelude622's Avatar
xb comes with synthetic from the factory??
Old Aug 19, 2008 | 06:41 PM
BBN-Boys's Avatar
^^ Can someone confirm that?
I was planning to do oil change @ 1K. I was thinking about going to my Toyota dealer to purchase thier Toyota 5w20 Synthetic oil.... maybe the same stuff for break-in?
Jyust wondering....
If changing just the filter, how much of the original oil comes out with the filter? How much oil did you put back in? if any?
Old Aug 19, 2008 | 07:23 PM
Shancopp's Avatar
I just had mine changed yesterday at 5200 miles and 6 months. THat and tire rotation are free (and at 10,000 and 15,000 miles). She didn't specify what type of oil, just said Toyota oil and filter.
Old Aug 19, 2008 | 08:41 PM
cnstarz's Avatar
5k miles, or 6 months, whichever comes first.
Old Aug 22, 2008 | 02:30 AM
spiderxB's Avatar
Check your manual before posting on here.
The xB does not com with synthetic oil and it is not necessary to use unless you are heavily modding your engine. Near the back of the users manual lists the oil requirements for the xB.
The guy that turned me onto the xB is a performance engine mechanic and even he said that synthetic oil for the xB was a complete waste of money.
Knock yourself out if you have the cash to blow, wont hurt it, but completely unnecessary with the stock or even partially modded engine.
Old Aug 22, 2008 | 03:02 AM
Invertalon's Avatar
In the manual, it states we should use 5W20 or 0W20, PREFERRED use of 0W20. Well, 0W20 is ONLY available as a synthetic. Doesn't exist as conventional.
Therefor, Scion wants us to use synthetic... You just have to read more closely to find out what our cars REALLY want!
Old Aug 22, 2008 | 03:22 AM
spiderxB's Avatar
Well, when I said to check the manual I was referring to the oil that comes in the xB from factory not being synthetic.
And since you sounded so confident, I decided Ok, maybe I was wrong, so i decided to double check.
"Geniune Motor Oil is used in your scion vehicle. Use Scion approved Genuine Motor Oil or equivalent to satisfy the following grade and viscosity. "
Grade: ILSAC multigrade engine oil.
Recommended oil viscosity. SAE 5w-20 OR OW-20. " (this does not say that OW-20 is recommended over OW-20) (pg. 263)
HOWEVER. I will agree that it does state. "OW-20 is the best choice for good fuel economy and good starting in cold weather."(pg. 241) Very general statement. Not scion or toyota specific.
This does not say that it is specific to what Scion wants us to use and you took the recommended statement out of context, you must be a politician. You can put words into Toyotas mouth all you want.
I simply stated that synthetic was not necessary to use, in which case I was absolutely right. Thanks for playing though.
Keep in mind as well that if you do not want to pay rediculous amounts of money for synthetic oil changes then I would not start doing it because you can not go back to conventional oil once to you synthetic. Not easily anyway.
Old Aug 22, 2008 | 03:28 AM
SW_08's Avatar
i hope you (predlude622) have your answer by now lol
Old Aug 22, 2008 | 03:45 AM
MotoXXX's Avatar
The first two oil changes are FREE! Why would you do it yourself?
Old Aug 22, 2008 | 03:52 AM
SW_08's Avatar
^ i was thinking that myself.....
Old Aug 22, 2008 | 04:41 AM
FromTheOld's Avatar
I recently posted a topic about this. I wonder, when is the "best" time to change your oil for the first time? I hear so many numbers its hard to believe one.
Old Aug 22, 2008 | 05:11 AM
buickid's Avatar
Because an oil filter is $5 or so. Isn't that cheap peace of mind? If $5 us a big deal, skip lunch and there you go, oil filter money. I did not, repeat, DID NOT change the oil, only the oil filter. The oil is still good, but I just wanted to change the filter since the initial engine break-in probably put a lot of junk in it.
zzbear
Apr 19, 2015 06:18 PM
voodoo2crue
Mar 18, 2015 01:30 AM
cid_mcdp
Jan 5, 2015 02:45 PM
scionman2003
19
Feb 26, 2004 02:55 AM
BlueBox
22
Nov 7, 2003 08:18 PM
