how to remove rear passender door actuator?!?!
hi folks - hope everyone is doing well.
my rear door lock actuator hasnt been working well and i bought the motor to replace it. i know how to remove the rear door actuator itself but i cannot pull it out of the door - the window guide gets in the way.
any idea on how i can pull the actuator out of the door?!
thanks in advance folks!
-mtd
-mtd
Remove whatever is in the way. The window is removed with 10mm bolts. And to remove the glass Guide slightly remove the weatherstrip. There should be a bolt at the top of the door and also by the regulator.
There's a 'regulator' in the door?
The "regulator" is the word most manufacturers use to describe the mechanism that raises and lowers the window. It can hand cranked (old days) or motor driven.
I actually prefer the old hand crank method... less too go wrong
