What does it mean when dashboard shows???
VSC light is light up, and the TRAC OFF button is also light up!!!!
It just started to turn on yesterday!!! what can it be!!!
name any modds you have done. If you just put in a CAI. check your maf sensor and make sure its clean and connected well and the piping is ok. If you have just put in a header. make sure BOTH sensors are hooked up rigth and that donut is inbetween the bottom of the header and mid pipe.
Im very new at this.... i just bought the car HAVE NO CLUE WHATS THE CAI or the MAF sensor
Whenever there is a error or a CEL it shuts off the supporting computers in case the problem is with them. For example, my moms Lexus she left the gas cap off. When it threw a code, it caused the TRAC, VSC, ABS lights to come on. It is just a safety measure to shut them systems off until you fix/clear the CEL. Get it scanned, and let us know what the code is and we can help more.
had the same problem... had driven through slush and then temperature dropped. Hubby power washed the wheels and those sensor lights are now off!!! Note: We drove through 2 winters in Wisconsin and that never happened but the slushy/icy type condition caused a problem.
You're car will throw codes from time to time its just the imperfections of drive by wire. If the car still runs fine it will most likely correct itself but I would still take your car to a dealer and have it scanned.
steeze69
May 24, 2021 02:57 AM
marsman328
Regional - Pacific Mid
Jul 28, 2015 09:43 PM
