Help! Need Part Number for Bolt/Nut/Bolt+Nut for Rear Susp.
Old Apr 15, 2009 | 08:43 PM
axtran's Avatar
Default Help! Need Part Number for Bolt/Nut/Bolt+Nut for Rear Susp.
I just noticed that I lost a nut that holds together my rear shock to the suspension (the 17mm bolt/nut that connects to the bottom of the shock). Does anyone know what part number it is for the nut, bolt, and/or both? Where can I look something up like this? When I owned a Honda, there were some detailed diagrams that stated part numbers... Scions have this?
Old Apr 15, 2009 | 09:12 PM
axtran's Avatar
Is the part number I just got from a Toyota Dealership. I'm going to order it!
Old Apr 15, 2009 | 09:38 PM
axtran's Avatar
I have a question to everyone viewing this post though... after I reinstall the bolts, loctite, and retorque--do you guys suggest torquing the bolt back on while the car is still lifted (no pressure on the tires) or torquing the bolt when the vehicle is on the ground? And how much torque? (I've read 32lb.ft so far, but I don't see why I shouldn't do a little more to make sure that sucker is going to stay in place)
Old Apr 15, 2009 | 10:15 PM
Invertalon's Avatar
You need weight on the suspension before you torque that bolt. Torque is 67ft/lbs. Make sure the nut is facing the wheel because it "locks" on that side. A little loctite 242 on the nut will ensure it won't come off.
Old Apr 15, 2009 | 10:51 PM
axtran's Avatar
Thanks for the advice. The rear suspension was easy, but tricky!
BrokenTC2
Jan 27, 2015 03:32 AM
NonStopTuning
Jan 20, 2015 05:20 AM
TheTripleC
Jan 4, 2015 06:46 PM
randomsuper
Dec 5, 2014 11:14 PM
umnitza
Dec 1, 2014 06:26 PM
