Lowering Question
Old Jun 6, 2013 | 05:19 AM
He_Is_Legend's Avatar
Default Lowering Question
Im going to order the Tanabe NF210's for a 2012 XB
I am wondering, after I install these will I need to get the car aligned? I believe I do need to but just want to double check.
..If I do have to get it aligned do I get a factory alignment or do i need to adjust the camber and get it aligned different then a factory specs? Thanks!
Old Jun 6, 2013 | 05:48 AM
xseveredveganx's Avatar
Utah Scions
Yes. To all of the above.
Old Jun 6, 2013 | 06:01 AM
Crylant's Avatar
If you want to run (-) camber in the rear due to wide wheels / going for a stanced look, then yes go for the negative camber. Make sure they actually zero out your toe, like I mean 0. Factory specs allow for an acceptable amount of toe, which makes it easier for alignment shops to get it within "spec" and send you on your unknowingly merry way. I'm running a really aggressive setup on my tC and even a little bit of toe will cause rubbing. My guess is you won't be having those kinds of issues just yet, but just my 2 cents.
Sent from my SGH-T999 using Tapatalk 2
Old Jun 6, 2013 | 04:38 PM
Thank you for the info this is great! In order to do negative camber do I need to purchase certain bolts or is that something the alignment shop can just do with me needing to buy any additional parts?
Old Jun 6, 2013 | 09:12 PM
Utah Scions
Camber isn't really adjustable in the rear...
Old Jun 6, 2013 | 09:21 PM
stenger's Avatar
What he said.
Rear camber can not yet be achieved on an xb2 due to rear disc breaks. In order to run rear camber, you need to tilt the rotors with the calibers and wheel hub. Adding shims will only tilt the rotors, and not the calibers. So that's not going to work at all.
Old Jun 6, 2013 | 09:46 PM
Utah Scions
Folks have been using washers, but I'm not sure how that will effect brake pad wear.
Old Jun 7, 2013 | 03:13 AM
Okay, since I am unable to due negative camber in the rear does that mean I should just do factory alignment specs then?
Old Jun 7, 2013 | 03:40 AM
Utah Scions
I'll answer your question with a question...
Why wouldn't you have it aligned within factory specifications?
Old Jun 7, 2013 | 03:48 AM
domoboiz's Avatar
stenger's Avatar
uneven wear easily. The inside pad will wear well before the outside pad. As well as the top of the inside pad, and bottom of the outside pad.
The only saving grace is that the brake balance is around 60-70% front bias. So most of the force is applied to the front pads.
Old Jun 7, 2013 | 04:15 AM
Well basically im wondering if there is anything I need to tell the alignment shop to get it aligned properly?
Old Jun 7, 2013 | 04:29 AM
Utah Scions
Tell them to align it.
Old Jun 7, 2013 | 04:35 PM
^^ Done this before on my Subaru....And it was anything but aligned correctly.
Old Jun 7, 2013 | 10:25 PM
Utah Scions
So go to some place good.
Old Jun 25, 2013 | 05:15 PM
scionblur's Avatar
Tanabe DF210's are nice but why are you trying to do a negative camber? Do you have wheels in mind?
Old Jun 25, 2013 | 09:40 PM
Utah Scions
Most people want the toe corrected due to lowering. It seems like every single axle that Toyota has made for these cars are off by minor amounts. I've been going through tires since I lowered my car over 5 years ago. I'm going to blame it on the toe being off so much.
However, I want a little more camber and the toe completely corrected. I already have my wheels but I want to go more aggressive.
bootlgr
Jan 26, 2016 01:22 AM
Greg S
May 28, 2015 12:46 AM
viciouzgamer
Feb 18, 2015 03:26 PM
TotalChaos
13
Feb 4, 2015 10:24 PM
torranosaurus
Jan 28, 2015 04:53 AM
