Measurements of Tanabe DF210 drop
I recently installed a set of Tanabe DF210 springs in my 2nd generation xB. In order to gat an accurate read on the actual amount of drop, I parked the car on a flat level surface and marked the location by putting masking tape on the ground next to each tire so I could park it in exactly the same spot after changing the springs. I took measurements from the ground to the top of each wheelwell arch and also from the ground to the lowest point in the center of the front and rear bumpers. I drove about 20 miles to my friend's house where we changed the springs, drove the 20 miles back, parked in the same spot and took the new measurements. Here's what I got:
............ .............. Before, After, Drop
Front bumper .... . 8.5" 7.25" 1.25"
Front wheel arch . 26.5" 25.0" 1.5"
Rear wheel arch . 28.0" 25.5" 2.5"
Rear bumper...... 12.75" 10.0" 2.75"
That was 3 weeks ago. I re-measured it today in the same spot to check for "settling". The numbers were the same as the "After" numbers above. If there was any settling, I guess it happened in those first 20 miles.
These numbers are a bit different from Tanabe's "advertised" specs. I believe they say the DFs will yield a 1.7" drop in the front and a 2.1" drop in the rear. Personally, I'm happy with a little less drop in the front and a little more drop in the rear. But I do find it strange that their figure for the rear drop would be 0.4" different from my reality.
I have trd springs installed for 6 weeks not much of a drop F 5/8” R 1-3/8”
------------------- stock / trd's
Front wheel arch 26.750" / 26.125"
Rear wheel arch 28.375" / 27.000"
I’m going to install the DF210’s this week end
Originally Posted by Maddman
hows the ride compared to stock set up?.. Im still debating,dont want to destroy the ride quality
Originally Posted by Papa
Good plan. Looks like your car sat a tad higher than mine in stock form.. It would be nice to get measurements from you after the DFs are in.
I finally got some free time to install my df210’s ( 18 x 7.5 +40 w/ 225-40-18 )
I also installed the trd struts/shocks w/ the df210’s very nice ride
imo the df210’s are a little softer ride then the trd springs
---------------------stock / trd's / df210
Front wheel arch 26.750" / 26.125" / 25.500”
Rear wheel arch 28.375" / 27.000" / 26.000”
xBrelease08
Scion xB 2nd-Gen Wheel & Tire
12
Feb 29, 2016 05:39 AM
ScionLife Editor
Sep 24, 2015 10:50 PM
