Rattle at rear after TRD Spring install?
Old Apr 20, 2008 | 01:09 PM
kregghill's Avatar
Default Rattle at rear after TRD Spring install?
Just a quick qustion??? After installing my rear springs... I get a rattle at low speeds going over small bumps. The only thing I can think of that might have gone wrong was that I reverse installed the lower shock mount bolts so that the nut faces inward instead of towards the wheel. Could I also maybe have installed the top spring seat backwards???
Old Apr 20, 2008 | 09:46 PM
UNOHxB's Avatar
check the shock bolt, if it wasnt torqued enough it could have come loose. also, the springs would probably make a creaking noise if they were installed wrong on the spring rubber.
Old Apr 20, 2008 | 11:56 PM
MikeInABox's Avatar
Yeah what he said.
Old Apr 24, 2008 | 11:12 PM
roXor_boXor's Avatar
Yup.
I developed a rattle that sounded exactly like a broken shock on the right rear last June after I installed TRD springs and rear sway bar. I checked it visually and grabbed and shook everything. nada.
I decided to recheck all the torques on the rear Sway bar install. The lower shock attach bolt tightened almost 1/2 turn and the noise went away. No return of the noise in 10 months.
Be aware that for whatever reason the nut does not turn easily. I torqued it by turning the bolt the second time. Contrary to anything else I have seen but it worked in the end.
Old Apr 24, 2008 | 11:52 PM
pinkysbox's Avatar
I got DF210s on my box. Is it more of a "rattle" or is it a "clunk"? I got some clunking coming from the driver's rear so should I recheck the bolt then?
Old Apr 25, 2008 | 12:53 AM
MikeInABox's Avatar
Yeah any noise back there after a spring install check the shock bolts. That's really all it could be, unless the spring isn't seated right. But that would probably make it sit uneven in the rear and you'd notice right away.
I installed a rear sway bar, then NF210's later, and last night swapped out for DF210's. I've never had any noises coming from the rear. Plus, anytime I've read about noises in the rear after a suspension mod, it's been those bolts.
Old Apr 25, 2008 | 03:00 AM
UNOHxB's Avatar
another thing to check, when you springs came in they are suppost to have either rubber or some sort of tape looking stuff on the smaller coils up top. this is so when the "soft" coils are maxed out they dont make a clanking metallic sound. if you removed them im sure you could use some old thin walled rubber tubing or something to use on them
Old Apr 25, 2008 | 03:41 AM
kregghill's Avatar
I thought that there was supposed to be some kind of black tubing but there wasn't?!? These springs were sealed and purshased at local Toyota dealer.
Hmmmmmmmmmmm?????
Old Apr 26, 2008 | 01:02 AM
pinkysbox's Avatar
Cool beans, I'll retorque the bolt tomorrow if the temperature is feasible.
DJ_FroZone
25
May 30, 2019 07:17 PM
JPuehl
Jan 10, 2015 01:01 AM
kleecker
Scion xB 2nd-Gen Wheel & Tire
12
Dec 31, 2014 04:07 PM
kleecker
Dec 31, 2014 09:42 AM
minter66
Dec 15, 2014 01:45 PM
