17 x 7.5, 42mm Offset on 245/45/17 - Going to Have Issues?
Old Jul 29, 2008 | 07:23 PM
tamu1996's Avatar
Default 17 x 7.5, 42mm Offset on 245/45/17 - Going to Have Issues?
I'm planning on running a set of Diamo 26 Karat's on my 09' xB.
Specs are 17" x 7.5" with 42mm offset and I plan to use a 245/45-17 tire.
Questions:
Will these look OK with such a high offset (I really want a fender-flush look, or close to it)
Will I have any rubbing issues?
Will I have any problems once I've installed the NF or DF drop springs?
Thanks, in advance, for the help.
Old Jul 29, 2008 | 09:40 PM
CIONIDE's Avatar
I'd recommend 235/45-17 tires to ensure that you don't have any rubbing issues up front when you drop it, additionally, 245 is pretty wide for a 7.5" wheel (buldging sidewalls).
17x7.5 +42 will sit back about 1/2" behind the face/edge of the front fenders and a little bit further in on the rears.
Old Jul 30, 2008 | 12:25 AM
tamu1996's Avatar
Thanks for the reply.
Will I have the same issue with the NFs and the DFs?
I don't have any issues going with a 235 tire, but will the tire/wheel set too far inside the fender well to look............umm..........."good" or, at least, not like wagon wheels on a Caprice?
--Ryan
Old Jul 30, 2008 | 08:01 AM
CIONIDE's Avatar
If you're going for NF's get 235/45 tires for 17x7.5 wheels.
If you're going for DF's get 225/45 tires for 17x7.5 wheels.
Old Jul 30, 2008 | 01:34 PM
tamu1996's Avatar
Thanks, Cionide.
Actually, I made a mistake in my original measurements. The tires are actually 225/45's, not 245. Sorry, fat fingers and all.
--Ryan
Old Jul 30, 2008 | 04:33 PM
CIONIDE's Avatar
If you're not sure which spring drop you will be going with, just play it safe and get the 225/45-17's. They're what most people go with. I just personally like the extra meat on the ground and slightly taller sidewalls of the 235/45's.
Old Jul 30, 2008 | 04:47 PM
motoretro's Avatar
If you want a slighter taller sidewall, why not use a 225/50/17?, Not sure if they make such a beast although if they do, this might work well.
Motoretro
Old Jul 30, 2008 | 06:26 PM
tamu1996's Avatar
motoretro, I've considered that, and 225/50's DO exist, but not in vast quantities.
I will likely go with the DFs, so I plan on keeping the overall profile the same height as stock, or close to it, with the 225/45s.
Thanks for the input.
Docofmind
Feb 25, 2007 06:01 PM
HemanC
Jan 20, 2004 03:29 PM
westsype
15
Dec 16, 2003 11:50 PM
OOHC
16
Dec 11, 2003 08:24 PM
smilygo
Oct 1, 2003 07:03 AM
