18 inch offset with coilovers help!!!
I want to run 18 inch esr sr01 but I want the deep dish look with limited poke. The site I'm going to order from gives me an offset choice of +22 or +35 if I go with 18x9.5, and +30 with 18x8.5. I'm also concerned with clearance from the coilover set up. What should I do????
9.5 with +35 will sit slightly outside the fender in the rear and +22 is going to sit about 1" outside the rear fender. Both will have about 1/4" more poke if put on the front.
8.5 with +30 will be right around flush in the front and just a tiny bit tucked in the rear.
If you want it all to sit close to even with both fenders I would go with the 9.5 +33 rear and 8.5 +30 front.
