18" vs. 19" Ride Quality
Old Jun 17, 2008 | 11:01 PM
XBnewbie's Avatar
Default 18" vs. 19" Ride Quality
I picked up my XB today. I am going to get new tires and wheels this week. It seems that most people are running 19", but I love the way it rides now. Do the XB2's ride ok with 19's? I realize I have to give up some ride quality, but I alos don't want it to ride like a tank. Also what does Staggered Wheels mean. Thanks for your help.
Old Jun 17, 2008 | 11:04 PM
xFistsClenchedx's Avatar
I think staggered wheels is when they have different wheel sizes in the front than the rear.
Old Jun 17, 2008 | 11:09 PM
xseveredveganx's Avatar
Utah Scions
Staggered wheels have a different width from front to rear. So rears are wider and have more of a lip. Only reason for doing this with a FWD vehicle is aesthetics. It looks cool, but limits how you can rotate your tires, thus reducing tire wear.
If you don't plan on lowering your xB (which I would and have) you could run 19's with the 235/35R19 tire. Heck, you could probably even run that with mild lowering. The difference in 18" tire size to 19" tire size is fairly minimal.
I'd think they'd ride pretty similarly.
Old Jun 17, 2008 | 11:21 PM
XBnewbie's Avatar
Thanks I am planning on lowering it. Does the TRD kit work well?
Old Jun 17, 2008 | 11:25 PM
Utah Scions
The TRD is a VERY mild drop. I've never ridden in an xB2 with the TRD's, so I can't attest to how they feel. I have the Hotchkis TVS kit and I've also lowered an xB2 with Tanabe DF210's.
I love how my car rides and handles now. It's a little on the low side. So if you don't want something as low, I'd go with the NF210's from Tanabe.
There's a thread here in the suspension part of the forum with a bunch of pictures and testimonials.
Old Jun 18, 2008 | 12:22 AM
CIONIDE's Avatar
Staggered wheels simply means that the fronts are different than the rears. It can be wider on the rear than the front (as mentioned above; you can run a larger diameter wheel on the rear than the front; or you can have different offsets on the rear than the front. Some people run a different offset on the rear to get the wheels to sit more flush with the fenders, in an attempt to match the fronts without going to a different width wheel and tire.
I vote for the Tanabe NF210 springs, heres the thread severedvegan was talking about:
https://www.scionlife.com/forums/viewtopic.php?t=206857
Old Jun 18, 2008 | 01:17 AM
my_cubicle_part2's Avatar
you can also run 40's with 19" wheels
Old Jun 18, 2008 | 02:42 AM
cubanix's Avatar
im riding 19's staggered with trd kit which its perfect for me, not to low , I think it rides well..can't tell you on the 18's but i can imagine been about the same..but bottom line its what you want . jut understand what you will run into the long run.
Old Jun 19, 2008 | 12:33 AM
fuqua's Avatar
cubanix do you have a few go shots of your car. I was thinking about the same wheels. Thanks.
Old Jun 19, 2008 | 01:28 AM
cubanix's Avatar
you can click on my name icon and see more on my profile..
Old Jun 19, 2008 | 06:46 AM
JettAntonio's Avatar
XBnewbie,
xseveredveganx is right bout d ride quality between d 18s and 19s. It all depend on the type of springs you got. I'm running on 18s with TRD drop and I have no complaints. I had a Tanabe springs on 17s on my 01 GTS. I can tell you the TRD rides better but the Tanabe looks better.
Hopefully, we all helped you out with your question. Post some pix after the drop.
Old Jun 19, 2008 | 03:32 PM
fuqua's Avatar
lookin good cubanix
Old Jun 19, 2008 | 05:41 PM
XBnewbie's Avatar
Thanks for the help. I looked at your pics, and I think that your set up is perfect. I would love if I could get the wheel and tire specs. ie front and rear width, offset, and tire size. Also any problem with rubbing? Thanks so much.
Old Jun 19, 2008 | 08:03 PM
cubanix's Avatar
thanks!!
check out this forum for the details
https://www.scionlife.com/forums/viewtopic.php?t=212390
Old Jun 19, 2008 | 09:01 PM
XBnewbie's Avatar
Thanks I read that thread that you sent me. There were a lot of varied opinions. What did you finally end up going with. Did you stagger?
thanks!!
Old Jun 19, 2008 | 10:00 PM
cubanix's Avatar
thanks!!
yes i did....19's staggered 8.5 front +40 offset 9.5 back +40 offset
235/35/frnt 265/30 back no rubbing issue, only once when i ran into a dip by accident but even that was minor.. i also recommend tires with Treadwear 300 to last longer . hope this info help and good luck on your decision.
Old Jul 7, 2008 | 04:05 AM
MotoXXX's Avatar
They say 18" tires are a lot cheaper to replace than 19" tires.
Old Jul 7, 2008 | 05:45 AM
CIONIDE's Avatar
225/40-18 is one of the best priced & most common tire sizes for 18+ inches (and perfect for the xB2); they should go on 18x7.5 or 18x8 wheels.
Old Aug 19, 2008 | 12:17 AM
whartman77's Avatar
Default 18s vs 19...
To me I looked at what Scion offers as alternative wheels. The TRD wheels are 19's and really if you look at pricing the wheels alone the 18's and 19's usually are not that much different in price. I personally have gone with a staggered set of 19's but now am getting nervous about the offset for the rear (both the fronts and rears are a +38 offset and the 9.5's out back mounted alone look REAL close...but can't really tell until the tire is on). I am waiting on the tires that are on order, tire and wheel combo (staggered) will be more of a looks thing than anything; I like the unique combinations so I went with RPM 505s wrapped in BFG KDW's.
I have the TRD springs, sway bar and strut tower bar, and with stock rims and tires it handles great! So I am really waiting to see what the new wheels/tires will do.
mischman
Sep 15, 2015 03:38 PM
Threequalseven
Aug 26, 2015 04:24 PM
Ismvelas2
Aug 17, 2015 02:22 PM
Subaru86
Jul 31, 2015 04:33 AM
