18x9 +35 in the front will they rub...
Old May 27, 2010 | 03:39 AM
papo's Avatar
Default 18x9 +35 in the front will they rub...
on the inside of the fender?
Old May 27, 2010 | 01:21 PM
Ace83's Avatar
Ronin Scion
yes.. more likely it will.. but also depends on how low the car, tires, and alignment.. even 18x8 35 will rub
Old May 27, 2010 | 04:09 PM
CIONIDE's Avatar
Stretch some 215/40 tires & pick up a set of Eibach front camber bolts to dial in some negative camber, and you should be able to pull it off. Maybe a little fender rolling also.
Old May 27, 2010 | 06:17 PM
papo's Avatar
yeah i have the camber kit, and im going to run a 215/40 im just wondering if im going to have to bang in the fender well w/ a hamer for extra clearance, trying to get my mind prepaired. im use to doing this on old cars not new ones. :scared:
Old May 27, 2010 | 10:47 PM
CIONIDE's Avatar
A fender roller and heat gun make it a lot easier & less stressful.
Old May 27, 2010 | 11:29 PM
papo's Avatar
yeah im not worried about rolling the fenders im asking about the inside of the fender well
Old May 27, 2010 | 11:34 PM
CIONIDE's Avatar
IIRC the inside liner is just plastic, not metal. I don't think it would be a rubbing problem as long as you clear the fender itself. The times I've seen liner clearance problems are when people go with over-sized tires to get some sidewall height back on + sized wheels.
yardleyTC
Mar 6, 2015 10:03 PM
pro5man
Scion xB 2nd-Gen Wheel & Tire
Mar 4, 2015 12:38 AM
meechindisbeech
12
Feb 28, 2015 04:20 AM
ploniaczysko
Scion tC 1G Wheel & Tire
Jan 28, 2015 02:15 PM
SkateVandal
Nov 27, 2014 02:34 AM
