City driving with 18's
Old May 6, 2008 | 01:51 PM
flyer172's Avatar
Default City driving with 18's
I finally found the rims I want but having trouble deciding on the size. (17's or 18's) I would like to get 18's and maybe even lower it but am concerned about rough roads as I drive in Manhattan 5 days a week. Does anyone have experience with 18's in a city environment they could share?
Old May 6, 2008 | 03:10 PM
DREWxB08's Avatar
Default Re: City driving with 18's
I had a set of 17's and than i had 18's on my xb'2 now back to stock till i get my new wheels.
With the 18's it felt fine to me i had a thick tire not so much a low low low profile, i live in queens and between Flushing , Astoria and the City it held up and felt normale to me and im lowared on Tanabe NF-210's. 17's just felt little lighter to the steering wheel but not buy much. and with past car's running on 18's i never bent a rim and i drive all over.
Old May 6, 2008 | 04:59 PM
bbscionxb's Avatar
well i post early here... i have df210 with echo struts and supra shocks in the rear and before i have 17s and my ride was good now i put 19 on the box it ride like ____,,,i could feel every bump and tire is like a rubber band but it looks good
Old May 6, 2008 | 08:05 PM
flyer172's Avatar
Yea I'm going with a tire that will give me an accurate speed reading which for 18in rims I believe it would be a 40 tire. Pretty low profile I quess. Thanks for the input.
Old May 7, 2008 | 03:47 PM
Whispaz's Avatar
18s with NFs. no problems here but im also ALWAYS on the lookout for potholes
Old May 12, 2008 | 03:51 AM
bendeng's Avatar
Scion Noics
Default new owner
im sorry if this question sounds dumb:
so the bigger the wheel size, the more you'll feel bumps on the road?
Old May 12, 2008 | 11:58 AM
chadfo's Avatar
Default Re: new owner
Not directly. When the wheels size goes up most people chose tires to keep the same outside diameter so the speedometer stays accurate and there is less chance of rubbing. Doing this means the sidewall of the tire is smaller. A smaller sidewall can't flex as much and absorb bumps so the suspension has to do more work. In the average car the suspension can't absorb everything so that energy is transferred into the chassis where you feel it.
Old May 12, 2008 | 12:38 PM
flyer172's Avatar
So far I'm getting the impression that the 18's are dooable, unless anyone has a horror story about 18's w/40 series tires they would like to share.
Old May 12, 2008 | 02:26 PM
Zsanz's Avatar
should be fine with a 30-35+ sidewall
Old May 19, 2008 | 03:38 AM
mikeyxB's Avatar
18x8 here on 224/40 kumho and NF drop. Bumps are the worst in the rear..in the front the ride is quite ok. flushing, manhattan, brooklyn, just take it easy. and slamming on the brake when hitting pothole causes a larger shock then accelerating so def take it slow and be careful. tires are expensive and nyc chews up wheels/tires
Old May 19, 2008 | 04:44 AM
DREWxB08's Avatar
Same here, have a set of 18's on at the moment that im testing out and man the bumps are def worse in the back and im on NF's as well Looks sweet but def gotta be careful. Im run thru Flushing, Bayside, longisland and city,,, I already bent a steelie and i drive like a granny over bad street's
Old May 19, 2008 | 12:31 PM
flyer172's Avatar
Do you guys wish you had gone w/the 17's ? I was just about to order the 18's untill I saw the last 2 posts LOL! BTW, NF210's ordered and on the way.
Old May 19, 2008 | 05:30 PM
DREWxB08's Avatar
Na i would def Stay with the 18's, Look's Great handles great on the freeway. Just gotta be careful on some strrets and speed bump's......
Old May 19, 2008 | 05:33 PM
DREWxB08's Avatar
And your gonna love the NF-210's there Awsome.
Old May 19, 2008 | 08:01 PM
krausmc's Avatar
Default 18s with 225/40/18s
I had a set of 18s put on with 225/40/18 tires. I live in Boston which is potholeville. I was worried about the same thing but its been fine with this size tire. Just got to watc for potholes, more concerned with bending my Enkei LF-10's than anything else.
Old May 19, 2008 | 08:39 PM
CIONIDE's Avatar
Most people seem to run 225/40 tires on 18's but depending on the wheel width, offset, and spring drop; you can also step up in tire size to 225/45 or 235/40 to get a little more sidewall. (Yes, if you go all the way up to 225/45 your speedo will be off a little bit.)
Old May 19, 2008 | 08:45 PM
flyer172's Avatar
Alright, that does it. 18's it is. Now I have another problem. I have waited so long that now I'm not sure I like my rim choice anymore. Does anyone have an opinion? Keep in mind my car is nautical blue http://cgi.ebay.com/ebaymotors/ws/eB...227541658&rd=1
Thanks
Old May 19, 2008 | 09:04 PM
CIONIDE's Avatar
First off, those are 4 lug wheels, won't fit our 5x114.3 pattern.
Second, I personally think the fact that those wheels are a lighter and brighter blue than NBM will look terrible.
Old May 19, 2008 | 09:08 PM
flyer172's Avatar
Yes I know about the size, just using the pic and I'm starting to think the same thing about the lighter color looking terrible, thanks.
Old May 19, 2008 | 09:18 PM
CIONIDE's Avatar
Might I respectfully suggest something along these lines:
http://www.discounttiredirect.com/di...14.3&tc=KONAFT
They're available in 18x7.5 +45 offset, and 18x8 +40 offset. IMHO I think they would look great on NBM.
