New wheel question? Thanks
Alright, I am currently running 19x8 TRD wheels w/ 225-35-19 rubber on my 09 Xb. I believe they are +48 if I am correct. I am also on KSport coil overs. The new wheels I am looking at come in 19x8.5 +35 and 19x8.5 +45. I have no rubbing issues right now. Will they work? Also I will be running the same tires. Thanks for any answers and I am sorry for asking ANOTHER wheel question. And yes I tried the wheel calculator.
Yes, TRD wheels are +48 offset.
Not sure if you saw that yesterday I had answered your Visitor Message or not. (PM generally works best.)
Originally Posted by CIONIDE
The rear hubs sit back from the fenders about 1/2" more than the front, so if anything you would want the +45 offset up front and the +35 offset out back, not the other way around. If you want to be able to crank the coilovers down as low as possible, this is the set-up to go with; or better yet so that you can fully rotate tires & wheels go with +45 at all 4 corners with 10mm spacers in the rear (which would also make resale much easier down the road when you want to change it up again).
Beesh
Jan 9, 2015 06:30 PM
armyrockmorales
Dec 28, 2014 10:39 PM
