Is this set up okay?
Old Jun 15, 2012 | 03:46 AM
Renuco612's Avatar
Default Is this set up okay?
The size are 18x8 offset +32 114.3 5h and 18x9 offset +37 114.3 5h.
I want that flush look all the way around. A little poke is okay. Is running wider rims on the rear okay. I know it's good if the car is rear wheel drive but how bout for front wheel drive. What tires should I run?
I have a rs7 so I'm running on trd springs. eventually going to get coilovers. any suggestions on that?
Old Jun 15, 2012 | 05:33 AM
xseveredveganx's Avatar
Utah Scions
Should be fine with a 215/40R18 tire all around. Will need a fender roll in the rear after coilovers.
Old Jun 15, 2012 | 10:47 PM
tha_insane's Avatar
You may not need a fender roll in the rear if you run a stretched tire. Rolling is easy by the way and people need to stop stressing about it. Its pulling a fender that is tricky.
Old Jun 16, 2012 | 07:11 AM
The1one1's Avatar
I'm running df210 springs with 18x8.5 et28 front and 18x9.5 et28 rear. 215/40 front and 225/40 rear. No rubbing. You'll be good with the set up you mentioned.
Erager09
Sep 26, 2016 03:11 PM
danielv
Aug 26, 2015 07:14 PM
toyosg
Scion tC 2G ICE & Interior
Jun 1, 2015 08:43 PM
Tavito
May 28, 2015 08:42 PM
Tavito
