Stock wheels difficult removing
Have a 2010 XB with stock steel wheels and it seems that when removing wheels I always have to beat on them (a lot)from the backside to get them off. Should I be putting something like anti sieze on the back of the wheel and around the center before remounting?
Thanks
MDCruzer
Thanks
MDCruzer
I take the wheels off to switch to snow tires in winter and back to street tires in spring, plus I usually have 1 or more off while I service the car during the year. Just a real pain
Toyota had the same problem when rotating my wheels for the first time and they put some red grease (probably just wheel bearing grease) on the center of the rim. Never had a problem with rim sticking, wheel wants to fall completely off by itself when the last nut is removed.
Just put some anti-seize or high temp grease on the center and you should be fine, just don't use a lot, a little will do.
also check to see if your hub is rusted or any dirt is stuck there. i work at americas tire/discount tires and we have many many cars that are like this. its also good to get a wire brush on an impact drill and just grind the dirt and rust off the hubs.
After reading this thread.. one other thing comes to mind... OP.. What state do you live in? Also, when you mentioned taking off to put on snow tires and stating they are stockies... and that they are the "steelies" Could just be conditions where you live may be the root cause if they aren't sufficiently coated (paint or otherwise). But suggestions given by those who chimed in are good ideas.
eric_m
52
Jan 17, 2019 05:50 AM
scionlife
371
Jun 2, 2015 11:00 PM
darkshadowofxdeath
Dec 3, 2014 06:59 PM
