Stretching stock tire Question
Old Dec 25, 2008 | 09:26 PM
Neek's Avatar
Default Stretching stock tire Question
I am planning on getting some sportmax 16x8 with an 0 offset
my question is, is it possible for me to use my stock tires that i have on my 2nd gen?
also how much and where will I go upon getting my tires stretched
thank you
Old Dec 25, 2008 | 11:08 PM
CIONIDE's Avatar
Here are some pics of Sportmax wheels with 0 offset on an xB2 with DF springs from a different thread. I don't know the size of the wheels or tires, but by the looks of them they could be 16's with 205 tires. You might want to try pulling one of your front steelies, swapping out the TPMS sensor and tire onto the new Sportmax wheel and dropping the car on the ground and driving it to confirm no rubbing or problems. If it's all good with that first one, then go ahead and do the rest of them. Not my style, but this will give you an idea how far they will stick out past the fenders. I don't know which Sportmax wheels you're looking at, but some of them come in a +15 offset also.
Originally Posted by doudou
i found this scion gen 2 with 0 offset on df
the last pic is not on 0 offset but same branch of wheels
Here's the original thread: https://www.scionlife.com/forums/viewtopic.php?t=235541
Old Dec 25, 2008 | 11:11 PM
Neek's Avatar
thanks for the info
so the rims I should get 5x114.3 correct?
And I just want to make it clear. It is possible for me to take the stock tires right now and make the new sportmax wheels fit on it?
Old Dec 25, 2008 | 11:23 PM
CIONIDE's Avatar
5x114.3 is correct. I don't know how well the stock tires stretch, so you're going to need input from somebody who has actually put them on 16x8 wheels, regardless of offset, for confirmation that they will stretch without any problems.
Which Sportmax wheels are you looking at?
Old Dec 25, 2008 | 11:27 PM
Neek's Avatar
actually the exact ones on the white scion xb2 you posted
Old Dec 25, 2008 | 11:39 PM
CIONIDE's Avatar
I saw from an earlier post that you want to drop it on coilovers... you can forget about that with 0 offset wheels, you'd be riding the fenders on the rubber.
Of course MaxBoost will let you know that if you don't rub, they don't fit right.
Old Dec 25, 2008 | 11:41 PM
Neek's Avatar
i think ill be going with DF's in the end. I am on a budget right now
Old Dec 25, 2008 | 11:45 PM
CIONIDE's Avatar
Give it a try; the worst case scenario is they don't work or you don't like it, then you just sell the wheels and get something else. Right now Next Level Motoring has them for only $102 each: http://www.nlmotoring.com/XXR-Wheels-512-s/433.htm
I still think you'll probably rub over any big bumps or dips in the road, but I don't really know for sure.
Old Dec 26, 2008 | 03:21 AM
xseveredveganx's Avatar
Utah Scions
And, of course, he'd give the OP crap for running SportMax... :D
*sigh* I need wheels...
Old Dec 26, 2008 | 04:26 AM
CIONIDE's Avatar
True, but we can't all afford AME Shallen wheels.
You and me both.
Old Dec 26, 2008 | 05:35 AM
Neek's Avatar
how much does it cost to stretch tires?
Old Dec 26, 2008 | 06:02 AM
Neek's Avatar
will I put these wheels onto stock tires as well?
http://www.nlmotoring.com/XXR-002-Wh.../00268109.html
Old Dec 26, 2008 | 04:38 PM
CIONIDE's Avatar
Stretching tires shouldn't cost any extra; all it means is stretching the distance between the tire beads so that they seat on each side of the wider wheels, to mount tires that would normally be meant for a narrower wheel. Not all tires stretch well, and I don't know if the OEM Bridgestone or Goodyears do.
Both the XXR-512 and XXR-002 have the same wheel specs, but as I said above, I don't know how well the stock tires take to stretching.
Old Dec 26, 2008 | 05:26 PM
tainoxl's Avatar
Here is a link with the same XB2 above, I think he had rubbing issues with the Dfs.
http://www.clubxb.com/forums/f68/08-...ock-20060.html
Old Dec 26, 2008 | 08:30 PM
CIONIDE's Avatar
Moral of the story: you can have 16x8 with 0 offset, or you can have DF210 springs, but you can't have both.
Old Dec 26, 2008 | 09:04 PM
Neek's Avatar
whata bout NF;s
Old Dec 26, 2008 | 09:34 PM
CIONIDE's Avatar
NF's don't drop as much as DF's, but they're very soft springs. I'd recommend Eiback Pro-Kit (1"F/1.2"R drop) or TRD springs (1"F/1.5"R drop). Both of these are a little stiffer than the NF's, but with progressive rear coils will ride better than the stock springs. If you occasionally carry a full load of passengers and/or cargo, go with the Pro-Kit springs.
TotalChaos
13
Feb 4, 2015 10:24 PM
STCxB
11
Jan 9, 2015 04:30 PM
darkshadowofxdeath
Dec 3, 2014 06:59 PM
