Tire Pressure?
I have 225/40/18 with continental dws. Max pressure is 51 psi. I keep them around 45 and like the ride. It feels about the same as it did with the factory 205 with 35 pounds in them except better in the turns. But that's probably technically to high.
When the pressure gets low you may find the tires following road lines and paint stripes, that is a sure sign you need higher pressure. If it still does that when the pressure is near the max on the side wall, you probably need new tires
On the other hand a DRZ SM might be fun blow across.
I was gonna ask if you get decent tread life but I'll assume that is not your primary concern. I tend to inflate Road/Street Bike Tires 2-5 lbs above max, and usually get better than average tread life and no detriment to adhesion.
I live around Baton Rouge, la. Every road is under construction and none of them are ever finished lol. As for tire life. I get average life for running a low profile sport tire. I've got right at 60k on the car and I'm about to need my third set.
Ah! Never been in La. Will Ride Dual Sport if I attempt it. Thanks for the heads-up.
Sooby
Scion tC 1G Wheel & Tire
11
Apr 8, 2020 11:51 PM
kingofthecrate
Jan 21, 2015 09:28 PM
