TPMS transfer
Can the stock TPMS be transferred from the stock 16" to 18" aftermarket rims? Im getting tired of driving around with the yellow low tire pressure light on for three years now.
yeah if you have access to a tire machine, break the bead on the tires near (bout 6 in on either side) but not directly over the sensor and use a 11mm ratchet to remove and install the sensor. tighten until snug.
dont over tighten or you can break the sensor.
dont break the bead directly over the sensor or it can break the sensor.
re-air to seat the beads then set tire pressures.
kleecker
Scion xB 2nd-Gen Wheel & Tire
May 22, 2016 06:10 AM
