Wheel fitment question?
Looking at going from my 19x8's TRD's to a set of 18x8's on my 09 Xb. The fronts are +35 and the rears are +30. I am dropped on Ksport coilovers. Am I looking at issues with this offset? Thanks in advance for any info.
Fronts are going to poke slightly, about 5mm. Depending on your tires and drop you're going to need to roll the fenders and possibly pull them. The rears should be fine and damn near flush.
Both front & rear should be pretty close to dead flush with those offsets. You could run 225/40-18 tires if you keep the Ksports stiff, but 215/40-18 will allow you slam it down more and have the tires tuck better with no fender rolling necessary.
if you run a 215 in the front, im pretty sure you will not have a problem i had x9+31 in the front and i got away without rolling the front fenders. as for the back again i doub't you'll have to roll the fenders. Of course this is depending on the tire your going to be running.
scionlife
371
Jun 2, 2015 11:00 PM
Beesh
Jan 9, 2015 06:30 PM
armyrockmorales
Dec 28, 2014 10:39 PM
