Wheel width/offset question
Old Jan 8, 2008 | 05:06 PM
hotboxn's Avatar
Team Echo
Default Wheel width/offset question
Im trying to figure out if a set of wheels would fit on a 08 xB. They are 19x9.5
with +25 offset and rears are 19x10 +20 offset. Any help would be greatly appreciated.
Old Jan 8, 2008 | 05:27 PM
SiXX's Avatar
No way... won't work. Not by a longshot. The fronts need to be more around 8.5" wide w/ an offset of at least 35mm or higher.
Old Jan 9, 2008 | 01:49 AM
CIONIDE's Avatar
One more time:
Here's the tire & wheel calculator:
http://www.rims-n-tires.com/rt_specs.jsp?postId=906
Keep in mind that the stock tires are 205/55x16" with +45 offset
Old Jan 9, 2008 | 01:57 AM
xseveredveganx's Avatar
Utah Scions
Originally Posted by CIONIDE
One more time:
I vote for a sticky of stock wheel size and what size wheels/widths/offsets will work...
I know on the other forums there's sticky'd info.
Old Jan 9, 2008 | 02:26 AM
CIONIDE's Avatar
The big benefit of checking the calculator yourself is that in addition to knowing if a particular wheel should work or not, is that you also find out how it will actually change (how much more or less it will change in distance from the fender lip, how the overall diameter will change, how much the speedo will be off).
I don't mind the Sticky idea, but I think it should also include the calculator link.
Old Jan 9, 2008 | 02:53 AM
randomsuper's Avatar
that calculator link is great. should definately be in a sticky.
Old Jan 9, 2008 | 03:12 PM
DiscountTireDirect's Avatar
Here is some width and offset stats from our fittment guide. Anything that falls outside the offset ranges will have a chance of rubbing. As a lot of you will want widths and offsets outside these ranges ask your fellow SL members for tips on getting them to fit.
WIDTH , OFFSET , TIRE WIDTH SUG.
6.0 , +14/+65 , 195
6.5 , +20/+65 , 195/205
7.0 , +26/+65 , 205/215
7.5 , +33/+60 , 215/225
8.0 , +39/+54 , 225/235
8.5 , +45/+47 , 235
Old Jan 9, 2008 | 03:20 PM
***Also remember that every wheel has a different x-factor. (x-factor is the curve, or contour, of the back of the spoke) X-Factor's can interfere with break caliper components so whenever you put a new wheel on your car always, always test fit it first to make sure there is no clearance issues.
Old Jan 9, 2008 | 05:07 PM
hotboxn's Avatar
Team Echo
thanks for all your help
TotalChaos
13
Feb 4, 2015 10:24 PM
toyotaisme
Jan 10, 2015 10:24 PM
Beesh
Jan 9, 2015 06:30 PM
ft86chick
Scion FR-S ICE & Interior
Jan 8, 2015 05:59 PM
armyrockmorales
Dec 28, 2014 10:39 PM
