will this rims work??? help
Old Apr 2, 2010 | 02:37 PM
kc2hje's Avatar
Default will this rims work??? help
I have a chance to get these at a good price since the box needs a hubcap and wheel from the crash
the q is will these work?
Cionide please help
And thank you in advance
Rim Brand: BBS Number of Bolts: 5 Rim Material: Alloy Rim Width: 7 JBolt Pattern: 5 x 4.50 or 5 x 114.3 Rim Diameter (inches): 16 Offset: 40MM
Old Apr 2, 2010 | 03:00 PM
oreoremix42's Avatar
Yea they should work. But cioncid will recomfirm
Old Apr 2, 2010 | 04:45 PM
BlackKnightxB's Avatar
Any idea what the center circle diameter is? that may also play into it, they may need to be machined a little to allow for the center of the hub.
Old Apr 2, 2010 | 06:07 PM
CIONIDE's Avatar
16x7 +40 offset and 5x114.3 (4.5") bolt pattern are all good to go.
As long as the hub bore is 60.1mm or larger, these wheels will work fine without any issues or problems at all. For larger hub bores you'll just need to get a set of hub rings.
Sooby
Scion tC 1G Wheel & Tire
11
Apr 8, 2020 11:51 PM
JPuehl
Scion tC 2G Wheel & Tire
Jan 22, 2015 02:44 PM
akwdcaveman
Jan 17, 2015 12:47 PM
TheTripleC
Jan 4, 2015 06:46 PM
