Will TRD Springs, 19x9.5 +45 Offset, & 235/35/19 Work?
Originally Posted by CIONIDE
Wouldn't try it on the front, but usually fine for the rear. The design of a few wheels doesn't clear the brake calipers in this size & offset, but 5mm spacers fix that problem.
If you're on the TRD drop and want to go with 235/35-19 tires, get the Lace wheels in 19x8 +45. If you want to flush out the rears to match the fronts, you can use 15mm rear spacers, but I'd say see how you like the look before buying the spacers.
Originally Posted by redline8k
now if only they offered them in 20.8.5 +45
19x8.5 +45 with 235/35R19 works well in the front. I think 9.5 wide is too much.
19x9.5 +45 with 265/30R19 works in the back, but it will need to be rolled- and you will still rub if the back is loaded.
kleecker
12-31-2014 09:42 AM
