Rattle and Grinding Noise under power..
Old Sep 30, 2021 | 02:07 AM
Ejoxd's Avatar
Default Rattle and Grinding Noise under power..
During acceleration there is a rattle grinding noise that is hard to explain sounds like some type of bearing.
The owner before me said that he replaced the axles 2 years ago and the noise went away.
It doesn’t sound like an axle noise that I have ever heard or wheel bearing.
Any help would be appreciated
___
Old Oct 4, 2021 | 04:54 PM
DannoXYZ's Avatar
Moderator
Moderator
inspect axles and wheel-bearings for looseness.
Old Oct 4, 2021 | 05:05 PM
drizzoh's Avatar
Could also be from a loose or bent exhaust heat shield or brake rotor dust shield if it does not end up being a wheel-bearing.
Old Oct 27, 2021 | 08:00 PM
Ejoxd's Avatar
Default Same here
Same thing here, the inner axel can sound a lot of ways when it goes bad, its not like the outer that pops when you turn. Bought a 09 XD recently and currently have the same grinding noise and the previous owner replaced the axels with cheap replacements and that fixed it for about a year.
i have also heard that it may be possible that worn engine mounts could be causing them to fail faster, don’t know how true that is
Old Oct 31, 2021 | 10:41 PM
Ejoxd's Avatar
Default From under the car
If i put it in gear while it is on jack stands and get it up to about 50 mph i can hear the noise. It sounds like it is coming from the drive axle baring in the transmission but could just be resonating from the inner axle…
update, i changed the the driver side axle noise seemed better but after driving for a while it was back to the same sound..
nkranhold
Mar 20, 2013 01:59 PM
grumpy6489
Regional - Pacific South
Mar 18, 2010 08:18 AM
06SuperWhite_SoCal_tC
Sep 20, 2006 07:23 AM
tallguy4u2luv
Apr 6, 2006 11:46 PM
hondaxhonda
Feb 19, 2005 11:48 PM
