transmission oil or differential oil
I have changed mine... twice to be exact. I use RedLine MT90, which is the correct spec for our xD's. I used RedLine MTL before, which not the ideal choice, but still within spec. I tow a lot, so I try to use all the best fluids.
Total threadjack but….Is there a write up here for the xD? I know you want to make sure you have access to the fill plug before you drain the oil. Beyond that I’m not sure what I would need to know.
the 2 big 21mm socket where the trans sit. there is a sticker on it too, can't recall what it said though. Bottom one is to drain and top one is to fill. You are going to need a long flexible funnel to fill it back up unless you have a pump.
kleecker
Apr 4, 2015 02:37 PM
Minsk99
19
Jan 22, 2005 05:09 PM
2006, adding, diferenal, differential, fluid, maintenance, oil, scheduled, scion, spec, tc, transmission, type, xb, xd
