Dash Cam hard wire?
Was just wondering if anyone has hardwired a Dash Cam into their xD?
Which fuses did you use a fuse tap on?
One has to be an accessory and one has to be constant power.
___
___
I was having a lot of issues with these cables from China. 3 of them they sent me didn't work correctly. (Viofo brand) I ended up finding this obd 2 connection kit and it has worked great ever since. Be aware that not all OBD II kits will work correctly if you want to use parking mode. Some of the other ones either
would either just supply constant power and not shut off after an hour like I set it on the dash cam or they would just turn off completely after a couple minutes of turning the car off. This one works perfectly but you may have to try a couple to see which one will work with your dash cam. I have the Viofo Pro Dual.
[url=http://Check this out on Amazon Car OBD Hardwire Kit for Dash Cam, DEEWAZ 12V/24V Mini USB Hardwire Kit with Low Voltage Protection, 24-Hour Mirror Camera Power Cable, Acc/Engine Mode (Micro Adapter Cable Included) [ame]https://www.amazon.com/dp/B08NT8YRQS/ref=cm_sw_r_other_apa_glt_i_BYVHYN1TVYEACP79XZ80?_encoding=UTF8&psc=1]Obd 2 connector [/ame]
lilman4210
Mar 23, 2005 02:50 AM
