Strange sub wiring question
I have a box with the amp attached. I would like to be able to remove it quickly to haul cargo but not have a hot battery and remote flopping around.
Is there a such thing as a quick connect for rca's/B+/ground/remote?
Thanks, Eric
Thanks, Eric
RCA's I would already consider quick connect, and you can do a quick connect for the Sub to Amp easily with connectors built into the box. Would also be easy to make one for the remote wire. Power and Ground would be much harder unless you are using a small gauge.
the rcas will be fine, as will the ground. its the hot remote and power that you have to worry about to aviod blowing fuses and melting the wiring. if you did the wiring right all your lines have spade connectors on them. they're about as close to quick disconnects as ur gonna get for 4 gauge wire. i'm in the same situation (infinity bass link powered sub) so i got rubber tubing to fit over the power wire from the h/w store. was a hair too big for the power wire so i put an xtra layer of heatshrink over connector so when i slid tubing over connector it stays on its own. same thing with remote line. hope this helps.
thats the problem i have have a box with 2 12' sitting in my room from my old car just cant decide what to do with. might just wait and JL might come out with a stealthbox like what they have for the TC
Originally Posted by TheICEbox
Will this work?
http://a763.g.akamai.net/7/763/1644/...p/VPID/1563363
That's exactly the same connector I mentioned was in the jon boat. Where did you find that? And what do you call it?
Thanks, Eric
Will this work?
Thanks, Eric
It is called a high amperage quick disconnect, this one is made by Stinger, there are other manufactures available which are all as good as the other.
bootlgr
Jan 26, 2016 01:22 AM
