2008-2010 [ZSP110]
How do I install HIDs into an XD?
Old Aug 30, 2009 | 02:28 PM
The5ickne55's Avatar
Default How do I install HIDs into an XD?
I bought a cheap HID bulb and put it into 100% stock headlights... since the reflector is there, naturally nothing happens, I just have some super bright white lights.
I found conversion kits, issue is I don't see how they help me get past the damn reflector.
(Also, do you guys think I should just switch back to regular bulbs?)
Old Aug 30, 2009 | 02:38 PM
Nateson's Avatar
https://www.scionlife.com/forums/sho...d.php?t=161061
This should help
Old Sep 1, 2009 | 02:31 AM
jay.diem's Avatar
+1 on this request... having trouble removing the H3 bulb...
There's not much clearance to work with near the headlamp assembly...
Should I remove the whole headlamp assembly, would this make things easier?
Old Sep 1, 2009 | 04:20 AM
Nateson's Avatar
No don't remove the entire assembly. After you unplug the lamp pull the rubber seal (looks like the bottom of a plunger). Now you should be able to see the lamp sitting in the assembly. There's a clip that keeps the lamp snug in there, on the driver sides headlight if I remember correctly looking down on it you should be able to see the clip on the left side of the bulb push the clip to the front of the car and then to the bottom of the car. Be careful and remember shimmy don't force.
Old Sep 1, 2009 | 04:59 AM
jay.diem's Avatar
Nate,
Thanks for quick reply bro...
ANy recommendations for location to put the ballast? If you got a picture of where you installed yours, that would be awesome :D
Old Sep 6, 2009 | 07:03 AM
uskrewed's Avatar
On the driver side I put my ballast on the fuse box, but some people may not like that :X on the passenger side there's a nice flat spot that fits a ballast perfectly.
DO NOT REMOVE THE HEADLIGHT ASSEMBLY! There is a 3rd bolt hidden beneath the bumper, so if you want to remove it you have to remove your whole bumper.
Old Sep 7, 2009 | 06:33 PM
jay.diem's Avatar
would you guys recommend Hi Xenon HID's or just one single HID for low beam, with halogen high beam?
Old Sep 7, 2009 | 08:15 PM
uskrewed's Avatar
I got the Hi/Lo instead of Bi-Xenon, but I don't think it was worth the price difference. Definitely go for the Bi-Xenon. With the Hi/Lo the halogen high beams are practically as bright as the Xenon lo beams.
Old Sep 25, 2009 | 12:47 AM
jay.diem's Avatar
hey Nate or anyone who installed the bixenon's HID's (only one bulb but have both high beam and low beam functions)
I am not sure which pin on the factory harness I should connect my low beam and high beam wires from the HID"s to...
Does it blow up the bulb or anything if I have it backwards?
Old Sep 25, 2009 | 05:07 AM
YELOSUB's Avatar
Wagonistas
Originally Posted by jay.diem
Nate,
If you take the front bumper off it makes things a whole lot easier in my opinion...Makes hiding the ballasts a piece of cake...I like my things clean and uncluttered...
Drivers side:
Passenger Side:
Old Sep 29, 2009 | 05:29 AM
jay.diem's Avatar
^^ awesome pix thanks!
just installed them this weekend and bixenon came out great!
Only problem is that they are pointed too low into the ground... anyone know how to adjust the vertical height?
Old Oct 18, 2009 | 05:20 AM
uskrewed's Avatar
There's an adjuster "screw" in the back of the assembly, but it's plastic so be careful not to break it. Make sure to record the height on the wall before you make adjustments so you know how much it's changed. Also be considerate and not point them too high up because you're going to blind the hell out of other people, and catch the attention of cops and get tickets
Old Jun 25, 2010 | 06:10 PM
two.0XD's Avatar
Nice pics man, BUT I am a little lost where you placed the second ballast...did you place that on top of the coolant tank? did you use to mount it on there? zip tires?
Old Jun 26, 2010 | 07:25 AM
YELOSUB's Avatar
Wagonistas
3M double sided sticky tape...Stuff will hold anything, just make sure to clean the area real good...
Old Jun 28, 2010 | 12:43 PM
JJGeneral1's Avatar
rubbing alcohol does wonders. i mounted my ballasts in the same location based of his pictures. they work great.
by the way, thanks for the photos to help!!!
Old Jun 28, 2010 | 03:06 PM
YELOSUB's Avatar
Wagonistas
Your welcome...Glad I could help...X2 on the rubbing alcohol...
Old Jan 12, 2011 | 04:07 PM
Zoo's Avatar
Zoo
Does anyone have any pictures of their installation with the wires to the headlight so I can get a better idea of where all the wires go?
Old Jan 12, 2011 | 05:01 PM
JJGeneral1's Avatar
They're plug and play. If you order a real set, they can't be connected wrong (except for positive/negative to battery). The only other issue you might get is high/low beams. If you aren't getting high beams when you "call" for them with the lever, change the plug around that plugs into your regular headlight to the kit.
Old Feb 10, 2011 | 02:43 PM
lllphoto_le3's Avatar
Default FAKE Phillips HID kits???
Hi. Do you guys think these kit are fake?
http://cgi.ebay.com/ebaymotors/PHILI...item2a0df1473d
http://cgi.ebay.com/ebaymotors/PHILI...item43a0505859
planning on getting an HID kit for my XD but i have heard and been warned about bad/generic/low quality/ebay crap HIDs. i do not know what or who to believe anymore so i did my own research and read about German made HIDs. So far ive read about the Phillips and AGT reviews and reviews sounded pretty good. Until when i browsed online to compare prices, i read another review about fake Phillips HID kits. Im still not quite sure about the AGT kits so im trying to still to the Phillips brand since im more familiar with the brand. But when i saw these two ebay listings, it kind of scared me since after reading the "fake Phillips" review.
OR
does anyone recommend a HIGH QUALITY / LOOONG Lasting / HIGH POWER / DURABLE HIDs kits? -Of course anyone that has them and had compare them to other brands? -on the budget also so please help?
thanks in advance. and please NO STUPID ANSWERS. im serious and really need suggestions.
Old Feb 10, 2011 | 02:45 PM
***if you look carefully on how they look, they look different from each other***
