what sway to choose
As far as I know you can get a sway bar for the Yaris and slap it on our car, same chassis. I have TRD and it works fine, I noticed it right away when I put it on last year. What I would love to find would be a front under brace since that would make handling even better.
I apologize if this sounds stupid. I don't know a lot about cars. So anyway, what does the difference in diameter do? Will the weight difference be an issue in the long run?
19mm vs. 23mm
I ordered my Scion XD earlier after lusting over it for a couple of years. Dealer said it will be a few weeks. Thanks in advance for the info.
19mm vs. 23mm
GT SPEC bars for yaris will also work with your xd. contact kevin chan at gt spec for all your needs....
Is the extra 4mm going to make that much of a difference? I can see where it would be important if you were serious about racing or something, but I'm thinking more along the lines of every day driving...
Also, how much of the Yaris Suspension stuff in the microimageonline.com store is interchangeable with the xD? I know they share the same suspension, but I wanted to check before I buy something that might not work.
Sorry, but it doesn't matter much.
The xD axle isn't enhanced much by a sway bar. Even a small bar will give you the maximum benefit. The larger bars will only add more weight.
More sophisticated suspensions sometimes do benefit from bigger bars, but for the xD, this is not an issue...
What makes you believe that a front brace will improve handling?
gedster314
Regional - Pacific South
Feb 19, 2021 07:51 PM
SloTC1
Aug 16, 2018 02:45 PM
Subaru86
Jul 31, 2015 04:33 AM
