Tire sizes
Old 06-23-2017, 10:04 PM
Bubbasparx's Avatar
Default Tire sizes
I have a 2014 Scion tC. Tire spec is p225 45 R18. I'm having a hard time around my area finding that specific size tire. So my question is can I put on 235 50R18's on with no problems other than the speeding a bit off? I also have to pass inspection with them and don't wanna waste my money if it won't be passable.
*moved to correct forum by moderator
Bubbasparx is offline
Old 06-25-2017, 01:41 AM
Administrator
Administrator
MR_LUV's Avatar
Hello Bubbasparx! Welcome to SL!
The 2015 Chart will be the Same for your 2014.
Yes, it will fit. But, you will have a -4.7% Speedo Error because of the bigger Diameter.
Also Check out the:
tC 2G+ Wheel, Tire and Offset Calculator
Personally, I would not go that route. I recently had the replace a tire with the OEM size 225/45R18. That is the only size I would use.
It is pricey but, you find find one online and for less than your local tire dealers.
Your Choice.
MR_LUV
MR_LUV is offline
scionlife
371
06-02-2015 11:00 PM
debris
12-16-2003 11:50 PM
BUzzBUcket
10
10-12-2003 07:19 PM
Quick Reply: Tire sizes
