Fuel Pump help
Old 09-10-2018, 10:16 AM
tmoneyflex's Avatar
Default Fuel Pump help
I have a 06 Scion xA. My car has been sitting for about 2 yrs. I went to get it back running and noticed I was not getting gas to the injectors. I located the fuel pump and tested the plug and I'm getting no power.
What should I check to see where my power problem may be. Ive done checked all the small fuses and a couple relays. Any help would be greatly appreciated.
*Moved to Correct Forum by Administrator. Please Do Not Post Technical Questions in the Introduction Forum!
Last edited by MR_LUV; 09-10-2018 at 08:15 PM. Reason: Moved to Correct Forum by Administrator
tmoneyflex is offline
Old 09-10-2018, 12:20 PM
Jon
Moderator
Moderator
Jon's Avatar
Pleasure hearing from you tmoneyflex. Make sure to add some pictures of your car to the Gallery and checkout our current photos while you're at it
Jon is offline
Old 09-18-2018, 08:27 PM
jimmyess333's Avatar
Sometimes there's more than one fuse/relay box.
One under the hood and one inside the car.
The lid to either should have a diagram of what each fuse & relay goes to.
It's hard to check a relay but you can try swapping relays from another slot to see if the harness going to the pump gets any power then
jimmyess333 is offline
hustler900
11-20-2023 11:05 PM
Danylucero
11-06-2017 08:53 PM
yamaha16bw
61
10-05-2017 02:39 PM
GetSlideways
Scion xD Drivetrain & Power
03-16-2015 11:30 PM
Jfitch004
06-16-2014 07:33 PM
Quick Reply: Fuel Pump help
