xA SRS light advice
xA SRS light advice
To anyone who may be more mechanically inclined than me,
My SRS warning light came on the other day driving home from work. I took it into the shop when I had a free day off about a week later to have it diagnosed. They came back and said that my clock spring had gone bad. I was quoted a large amount of money to have it fixed so I decided to just pick it up
and think about what I wanted to do for a few days, whether it would be to have it fixed or look for another vehicle as it was getting old. Driving home from the shop the light was off, I stopped at the store then the rest of the drive home it was on, then for the last four times I've driven it the light has been off.
In addition I was told that if the clock spring was bad the horn would not work but it was working with the SRS light on (literally used the horn on the way to the shop) and is still working.
So basically my question is this: If the SRS light is off, are my airbags working properly? I just want to be safe.
Thanks for your help!
Ty
Ty
Last edited by MR_LUV; 06-07-2019 at 04:15 AM. Reason: Moved to Correct Forum by Administrator
It should be working properly, but I'd rather replace the clock spring just to make sure. The job (if you're handy) is a 30 minute or so job. Let me look and see if I can find a tutorial for you.
Here's a generic DIY for clock spring replacement:
and heres a clock spring for $35
https://www.partsgeek.com/pnthyrc-sc...ag+Clockspring
Hey thanks for your answer! I'd love to have it replaced but was quoted $700 for the job and don't want to invest that much into my little xA and am not very experienced in doing things myself, especially when it involves removing the airbag.
Dealership clock springs cost north of $400 however Genuine Toyota clock springs can be had for less than $60/ shipped. Some Chinese clock springs go for less than $10/ shipped. Even if your mechanic wants you to have the best, I seriously doubt he needs $300 worth of time to install it.
I'd get a second opinion on labor-only (assuming you provide the part yourself.) Might save you a few hundred.
Check your private messages. I'll send you the link to an inexpensive, Genuine Toyota clock spring.
1slowsciontc
Scion tC 1G ICE & Interior
04-20-2019 10:51 PM
ozyborne
04-27-2017 06:16 PM
PatD
24
04-22-2006 07:07 PM
randode
52
11-23-2003 05:21 PM
